Old 07-24-2013, 09:56 AM   #1
tv antenna booster - where is it?
Is there a TV antenna booster in 3050S? Had lousy TV reception in MH. Same campground in the old RV got more stations. Hopefully there is one somewhere in the RV.
johnlantz is offline   Reply With Quote
Old 07-24-2013, 10:23 AM   #2
I had my 3051S antenna changed to the Wineguard model with the built in booster before taking delivery.
Tim
2013 Forester #3051SF
2009 Toyoda Tacoma (toad)
2010 Newmar Dutchstar (Sold)
2011 Fleetwood Bounder (Sold)
trwmodela is offline   Reply With Quote
Old 07-24-2013, 12:15 PM   #3
If its like the 2690, it is on the switch plate where the ant coax from the TV plugs into the wall, its a little push button switch.
Geri is offline   Reply With Quote
Old 07-24-2013, 02:24 PM   #4
There is only one even if you have multiple TVs. It's usually on the front or main TV connection box. Little button with a green light.
ATVer is offline   Reply With Quote
Old 07-24-2013, 02:27 PM   #5
Right. You should se a little green LED light on when the booster is on. I just changed my Winegard wingman out and put on a JACK antenna, very easy to swap out, and it works much better, so far. Randy
Old 07-26-2013, 07:26 AM   #6
Yep - I had a little green light along with a button on my old motor home. Went over last night searched everywhere in the RV and could not find any booster switch or button.
Old 07-26-2013, 07:29 AM   #7
Herk7769's Avatar
It is there somewhere. It is also the switch for controlling whether you use the park cable or roof antenna.
HAM CALLSIGN - KC3FFW
Old 07-26-2013, 05:57 PM   #8
DangerCliff's Avatar
Same way with my 2013 , 2860 can not find a booster switch anywhere. Don,t know how I would make out if I ever hooked up to cable, any help would be appreciated.
2013 Sunseeker 2860 Chevy
2014 Chevy Spark
Days Camped 2013 93.
Days Camped 2014. 89
DangerCliff is offline   Reply With Quote
Old 07-26-2013, 07:26 PM   #9
Don't you have a input selector/ switch box somewhere in a cabinet? If so press "cable" button on the front of the switch box for the correct TV you be viewing from.
4Gcampers is offline   Reply With Quote
Old 07-26-2013, 07:43 PM   #10
got it , so that would do the cable and the booster must be on all the time as there is no switch. Thanks for the help
2014 Chevy Spark
