Old 08-26-2013, 04:11 PM   #1
NCIC105's Avatar
TV Over Air
We were camping this weekend and noticed the TV in the front and outside only received 3 channels. The TV in the bedroom received 7...
I made sure switcher in the cabinet was set to living room and outside. Turned off each and tried again at each TV....
Checked connections....
Any suggestions?
NCIC105 is offline   Reply With Quote
Old 08-26-2013, 04:16 PM   #2
TURBS's Avatar
Did you do a channel search?
Turbs
Old 08-26-2013, 04:31 PM   #3
NCIC105's Avatar
Turbs
Yes on each TV.....
Old 08-26-2013, 04:37 PM   #4
LKicklight's Avatar
TV Selector
Did not know you could switch from front to rear or inside to outside TV's??/
Turbs
2500HD 6.0 Gas/Ext. Cab
2011 Crusader 270RET
2003 Sunnybrook T/T 30FIS
2012 Jeep Compass Limited
1985 S-10 One Owner:
LKicklight is offline   Reply With Quote
Old 08-26-2013, 04:38 PM   #5
Witch Doctor's Avatar
Check to see if each tv has all the box's checked in the menu. That could stop you from getting them if not checked, then do a channel search. They all should come up the same. If not then you really have a weird problem. Couldn't begin to tell you why. Good Luck......
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 08-26-2013, 04:39 PM   #6
I think the only other possibilities then are:
-defective switch box
-bad cables or connectors
-bad TVs.
If you can get to the back of the switch box, try putting the wire to a "bad TV" onto the bedroom outlet on the switch box (that you know worked well). That will help isolate the problem.
Old 08-26-2013, 04:55 PM   #7
Someone mention bad 90 degree adapters on the co-axial cables on the front and rear tvs. They removed them and got all the same channels on each tv.
Maybe worth a try.
kittyskeeper is offline   Reply With Quote
Old 08-26-2013, 07:22 PM   #8
NCIC105's Avatar
All boxes were checked....Set up antenna and scanned channels tonight..All TV's receive same channels today...Weird!
Old 08-26-2013, 08:08 PM   #9
Road-King's Avatar
I have seen with my TV's that different brands of TVs have different cut-offs for weak signals. I have even seen a digital converter box pick up more OTA broadcast then a newer digital TV.
If you have a TV you can move around you could check and see if it is getting the same number of channels on each coax connection.
Russ & Kim
2014 Alpine 3600RS
2007 Dodge Ram 3500 5.9 4X4
2008 Harley Davidson Road King 105th Anniversary
(2011-5 bad year)(2012-40)(2013-45)(2014-23)
Road-King is offline   Reply With Quote
Old 08-27-2013, 02:53 AM   #10
Glad you got everything working again. electronics who ever knows when fluke things happen just like my damn computer.....
