Old 03-30-2014, 11:55 PM   #11
also had the inverter checked when I had the gen. serviced last week inverter is oper. good
goots is offline   Reply With Quote
Old 03-31-2014, 12:10 AM   #12
Kaadk's Avatar
Originally Posted by goots View Post
you would think the inverter is on if the TV come on when the gen is tuned off
No, what I was trying to find out is:
A) Power from Gen straight to TV
B) Power from Gen -> Convertor -> Batteries -> Inverter -> TV.
If the Inverter was turned off when the Gen is supplying power then it's option A. If it was turned on when the Gen is supplying power it could be A or B.
What this helps identify is if there is a problem with compatibility between the Inverter and that TV. (See comment above about clean AC.)
There's no use crying over spilt milk, unless it's on your keyboard.
Kaadk is online now   Reply With Quote
Old 03-31-2014, 12:41 PM   #13
GM
bclemens's Avatar
I'm confused. What does the inverter have to do with it? If you have the Jensen LED TV's they should all be native 12V. Unless you have front ent. center.
Could be heavy draw on batteries, voltage drop causing issues? Although on ten power not sure why.
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
Old 03-31-2014, 01:13 PM   #14
SKnight's Avatar
If they're 12V televisions then it could be low voltage causing an amp overload (Devices run on watts actually, a 60 watt TV will draw 6 amps at 10V, 5 amps at 12V, 4.3 amps at 14V) kicking an internal safety.
Measuring the voltage at the plug will tell the tale. If low voltage is discovered then it could be any number of causes from poor tension on a connection to corrosion.
When plugged in the converter runs the system up to 14V or so, if it's running just a bit low then that makes up the difference.
Old 03-31-2014, 01:17 PM   #15
Kaadk's Avatar
Oh, if he's got 12v TVs then that's a whole different set questions. Post 1 thru 8 seemed to indicate he didn't and was powering them through an inverter (or straight from Genny).
Old 03-31-2014, 03:28 PM   #16
hay how you doing. just reading your problem. I'M not very handy but I would try another tv.if the same thing happens. take it to the dealer. let them try it and see. good luck.
Happyholidayer is offline   Reply With Quote
Old 03-31-2014, 03:42 PM   #17
thx for all the info, found the problem, the house batteries were low the TV in livingroom draw more power then the one in bedroom, was told to charge up the coach a couples of days before going out drycamping this problem I had never happens when at a full hook-up thx again
Old 03-31-2014, 05:22 PM   #18
dcheatwood's Avatar
Great! That was a tuff one. Glad its solved. Now, go camping. : ')
Sent from David's RAZR M.
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
Old 03-31-2014, 07:43 PM   #19
For sure, for sure thx mr. dcheatwood
Old 03-31-2014, 08:00 PM   #20
Kaadk's Avatar
Glad to see it worked out. Happy camping.
