03-30-2014, 09:36 PM
TV turns off
Help please?? I don't drycamp much but when I do I turn my TV on then after a couple of mins. the TV turns off then I turn it back on and again the same happens again, anyone with same problem, just TV in livingroom, bedroom TV works fine, on full hook-up everythings works fine thx '2014 Sunseeker 3010DS
03-30-2014, 10:09 PM
When you are dry camping, how are you powering your TVs? Are the 12v or you running a gen?
Sent from David's RAZR M.
2018 Forester 3011 DS
03-30-2014, 10:14 PM
I'm using gen. also have inverdor
03-30-2014, 10:16 PM
opps that's inverter
03-30-2014, 10:26 PM
Odd. Surely your gen is producing enough amp for 2 TVs. Does the one in question only turn off when both are on? Or also when it is only one on?
Just trying to get enough info for one our whizzes here to offer a solution.
03-30-2014, 11:04 PM
turns off when on by itself & also when both TV's are on
03-30-2014, 11:16 PM
Are you operating the tv from the generator power or the inverter power?
03-30-2014, 11:27 PM
I've done both still the same ,only when I have full hook-up service does it run fine
03-30-2014, 11:46 PM
Couple of questions:
1) Is the Inverter on or off when running the Gen?
2) Is the Inverter a pure sine wave?
3) Is the Gen a pure sine wave?
4) Have you tried swapping bedroom and living room TVs? Is problem location or TV?
5) If it follows the TV, are they different models?
6) If yes, see back to questions 2 & 3, some models are more picky about how clean their AC is vs others.
7) If it's location, well, no clue...
03-30-2014, 11:53 PM
you would think the inverter is on if the TV come on when the gen is tuned off
03-30-2014, 11:55 PM
also had the inverter checked when I had the gen. serviced last week inverter is oper. good
03-31-2014, 12:10 AM
No, what I was trying to find out is:
A) Power from Gen straight to TV
B) Power from Gen -> Convertor -> Batteries -> Inverter -> TV.
If the Inverter was turned off when the Gen is supplying power then it's option A. If it was turned on when the Gen is supplying power it could be A or B.
What this helps identify is if there is a problem with compatibility between the Inverter and that TV. (See comment above about clean AC.)
03-31-2014, 12:41 PM
Commercial Member
I'm confused. What does the inverter have to do with it? If you have the Jensen LED TV's they should all be native 12V. Unless you have front ent. center.
Could be heavy draw on batteries, voltage drop causing issues? Although on ten power not sure why.
03-31-2014, 01:13 PM
If they're 12V televisions then it could be low voltage causing an amp overload (Devices run on watts actually, a 60 watt TV will draw 6 amps at 10V, 5 amps at 12V, 4.3 amps at 14V) kicking an internal safety.
Measuring the voltage at the plug will tell the tale. If low voltage is discovered then it could be any number of causes from poor tension on a connection to corrosion.
When plugged in the converter runs the system up to 14V or so, if it's running just a bit low then that makes up the difference.
03-31-2014, 01:17 PM
Oh, if he's got 12v TVs then that's a whole different set questions. Post 1 thru 8 seemed to indicate he didn't and was powering them through an inverter (or straight from Genny).
03-31-2014, 03:28 PM
hay how you doing. just reading your problem. I'M not very handy but I would try another tv.if the same thing happens. take it to the dealer. let them try it and see. good luck.
03-31-2014, 03:42 PM
thx for all the info, found the problem, the house batteries were low the TV in livingroom draw more power then the one in bedroom, was told to charge up the coach a couples of days before going out drycamping this problem I had never happens when at a full hook-up thx again
03-31-2014, 05:22 PM
Great! That was a tuff one. Glad its solved. Now, go camping. : ')
03-31-2014, 07:43 PM
For sure, for sure thx mr. dcheatwood
03-31-2014, 08:00 PM
Glad to see it worked out. Happy camping.
