Old 03-30-2014, 09:36 PM   #1
TV turns off
Help please?? I don't drycamp much but when I do I turn my TV on then after a couple of mins. the TV turns off then I turn it back on and again the same happens again, anyone with same problem, just TV in livingroom, bedroom TV works fine, on full hook-up everythings works fine thx '2014 Sunseeker 3010DS
goots is offline   Reply With Quote
Old 03-30-2014, 10:09 PM   #2
dcheatwood's Avatar
When you are dry camping, how are you powering your TVs? Are the 12v or you running a gen?
Sent from David's RAZR M.
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
dcheatwood is online now   Reply With Quote
Old 03-30-2014, 10:14 PM   #3
I'm using gen. also have inverdor
Old 03-30-2014, 10:16 PM   #4
opps that's inverter
Old 03-30-2014, 10:26 PM   #5
dcheatwood's Avatar
Odd. Surely your gen is producing enough amp for 2 TVs. Does the one in question only turn off when both are on? Or also when it is only one on?
Just trying to get enough info for one our whizzes here to offer a solution.
Old 03-30-2014, 11:04 PM   #6
turns off when on by itself & also when both TV's are on
Old 03-30-2014, 11:16 PM   #7
Are you operating the tv from the generator power or the inverter power?
2016 Siverback 33IK
2015 Ford F-250 Lariat 6.7L V8 Diesel 4WD Super Cab
Old 03-30-2014, 11:27 PM   #8
I've done both still the same ,only when I have full hook-up service does it run fine
Old 03-30-2014, 11:46 PM   #9
Kaadk's Avatar
Couple of questions:
1) Is the Inverter on or off when running the Gen?
2) Is the Inverter a pure sine wave?
3) Is the Gen a pure sine wave?
4) Have you tried swapping bedroom and living room TVs? Is problem location or TV?
5) If it follows the TV, are they different models?
6) If yes, see back to questions 2 & 3, some models are more picky about how clean their AC is vs others.
7) If it's location, well, no clue...
The surest way to lose is to play Marco Polo with a ventriloquist.
Old 03-30-2014, 11:53 PM   #10
you would think the inverter is on if the TV come on when the gen is tuned off
