Old 10-04-2014, 07:47 PM   #1
2017 Georgetown 31L5
Two mysteries in our new 3010DS
Just home from our first run with a new 3010DS. All systems seemed to work well, no issues. Lots to learn as rookies. Two mysteries that need solved. First, we have 3 metal rods about 20" long that we found in one of the upper cabinets they are rubber tipped - we have no idea what they are used for??? Here's a pic.
Also we have 4 speakers mounted in the ceiling of the 3010DS and we can't figure out what and how to get sound out of them.
Anyone out there know anything about these items.
otilopnad is offline   Reply With Quote
Old 10-04-2014, 07:58 PM   #2
Ret E-9 Anchor-clanker
donanddona's Avatar
If they are adjustable could keep items restrained, or from falling off/out of the shelf's.
donanddona is offline   Reply With Quote
Old 10-04-2014, 08:00 PM   #3
tmhyer's Avatar
Do a search on here. Theyve both been answered several times.
The rods are for the slideouts to hold them in if they fail. I believe the radio has to be set to av1, and the tv speakers turned off
tmhyer is offline   Reply With Quote
Old 10-04-2014, 08:01 PM   #4
Alas they are fixed in length, no adjustment.
Old 10-04-2014, 08:08 PM   #5
The rods are for inserting between the interior motorhome wall and the upper slide trim when the slide is not extended to keep the slide from inadvertently going out while moving. Biggest problem is not to forget to take them out when extending the slide. I don't think a lot of folks use them. Your PDI person should have told you their purpose..
budblack is offline   Reply With Quote
Old 10-05-2014, 07:24 AM   #6
Mikegjax's Avatar
For your speakers, check your equalizer/fader setting. It may be set to the forward speakers only. Check audio source settings as well.
2014 Solera 24R
USN Retired
Mikegjax is offline   Reply With Quote
Old 10-05-2014, 07:09 PM   #7
Thanks to all for the responses. We are heading out again in a few days and will try these suggestions.
Old 10-06-2014, 08:58 AM   #8
Good luck! I have the same problem with the leaking low point hot drain. I tighten it every few weeks but it seems to vibrate loose over time. One of these days when I am motivated enough, I will put a better shutoff valve on there and eliminate the problem.
I do keep the slide bars on board. I never use them routinely but a fellow camper with a forester had a slide failure this summer and did use them to keep the slide in until he could get it repaired. So I put them underneath in my "probably will never use but might save my butt some day" box
jrwalkerpa1 is offline   Reply With Quote
Old 10-13-2014, 02:31 PM   #9
bb920's Avatar
I know they are used for the slide out, but I use them to hold up my bed if/when I need to get under it. They work great there and it's a good place to store them.
Bill & Kay
Green Bay, WI
2016 FR Berkshire 38A
bb920 is offline   Reply With Quote
Old 10-15-2014, 09:06 PM   #10
hockeytownmom's Avatar
Love these forums. I just found my rods, we're 100% sure what they were for, thought maybe the slides, but came here to check.
Kristina & Family
2015 Sunseeker 3170ds
'13 Honda Pilot -Kar Kaddy 3
Nights camped in 2011/36, 2012/9, 2013/24, 2014/27; 2015/50 2016: 34
hockeytownmom is offline   Reply With Quote
