Old 05-19-2013, 06:49 PM   #1
Sunseeker 2500TS owner
Unidentified connection, vent, what is it?
On the drivers side, under the table, in the storage area in my new 2500TS there is a vent or connector. It comes through the top of the storage compartment. It is a steel tube, with a horizontal hole in it, a steel cover over it, with a cotter pin through the tube, holding the cover on. There are no screw threads. I have no idea what it is or is used for? Dealer did not know. Anyone know what it is? Only thing above it in the RV is the table and seats around the table.
Thank you.. Emory in MD.
ejkkj is offline   Reply With Quote
Old 05-19-2013, 08:30 PM   #2
bikendan's Avatar
pictures are always helpful.
Equalizer WDH
Old 05-19-2013, 08:33 PM   #3
Outside storage or inside? If outside under slide its the shaft for the slide motor.
mwebber78 is offline   Reply With Quote
Old 05-20-2013, 08:26 AM   #4
It is outside storage. That sounds right. What is the purpose of having it there?
Can it be used to move the slide manually? If so how?
Thank you for the help...
Old 05-20-2013, 08:58 AM   #5
GM
bclemens's Avatar
If it has the cotter pin in it, its the slide height adjustment (for dealer use). There should be another shaft with a nut on the end...that would be the manual crank for the slide. Just put a ratchet on it. But again, pictures to be sure.
You can search for "Lippert manual slide" to find the video/thread talking about this.
Please READ the entire thread before posting to keep comments relevant.
Also, please post questions as a "New Thread" (not private message) so that others can benefit from the answers. Use Private Messages for sensitive information only. Owners manuals are available online and via iPhone/Android Apps.https://www.dynamaxcorp.com/OnlineManual.aspx
bclemens is online now   Reply With Quote
