Old 09-06-2013, 07:59 PM   #1
kbodrie's Avatar
Unknown switch
Newbee question, I have a 2013 3010DS and there is a toggle switch on the lower left of the drivers seat with a picture of a battery on it? Don't know what it's for? . Dealer did not tell me any thing about it.
kbodrie is offline   Reply With Quote
Old 09-06-2013, 08:05 PM   #2
VinceU's Avatar
Probably parallels the coach battery with the chassis battery for emergency start.
Old 09-06-2013, 08:28 PM   #3
x2. If chassis battery is dead and engine won't start, hold switch down and start using power from the coach battery. Unlikely you will ever need it but good to have just in case.
2012 Forest River Sunseeker 2300 Chevy
RvBill3 is offline   Reply With Quote
Old 09-06-2013, 08:38 PM   #4
kbodrie's Avatar
Thanks, good to know before I call someone to give me a jump. Doh...
Old 09-08-2013, 08:30 AM   #5
Just a note you need to depress and hold it for it to work..
mwebber78 is offline   Reply With Quote
Old 09-10-2013, 06:51 PM   #6
I have heard that this switch can also be used to start your generator by using the chassis battery if your coach batteries are weak. Maybe someone can verify if this is true .
JimV is offline   Reply With Quote
Old 09-10-2013, 07:26 PM   #7
VinceU's Avatar
Not a good idea! Instead, start the chassis engine and wait a few seconds, by then the alternator will be feeding the coach batteries. Then you can start the genset withhout taking out your last asset.
Old 09-11-2013, 04:40 PM   #8
GM
bclemens's Avatar
That is true if you choose to. It will also let you put the jacks down when the house batteries are dead. Learned that one at an RV show.
However you do need to hold it down the whole time.
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
