Old 05-30-2016, 04:48 PM   #1
Upgrade ac thermostat 3010ds
Wondering if anybody out there has upgraded their AC thermostat, from the stock. I want to upgrade it to one that will actually turn the air conditioner off once the RV reaches the temperature I want just like the one in my house
kitejunky1 is offline   Reply With Quote
Old 05-30-2016, 04:59 PM   #2
Chief tinkerer
Gidyupgo's Avatar
Thermostat
Hello. I don't know if this applies, but on our 3010, we just discovered that with the stock T/stat, the AC fan control is selectable to Au (auto), Lo or Hi. Accessed by cycling through until "fan" is highlighted and then either up or down to select. In Au, the fan shuts off when the AC does.
Gary
2017 SunSeeker 3010DS
Gidyupgo is offline   Reply With Quote
Old 05-31-2016, 06:51 PM   #3
DaGrinch's Avatar
Hmmm.... saw the "Lo" setting when we had the fan on and never thought to explore any further.
No offense, but, I'd be more impressed if someone came up with a good t/stat that didn't have the huge range when you had it on HEAT. Seems the one in my unit kicks off and then it cools down at least 5-7 degrees before the heat kicks back on. I can deal with the fan still running when the a/c hits the proper temp. But, those cool swings...... hard on the old man!
"Sunny" the 2017 Sunseeker 3010DS
2006 Jeep Liberty Toad
.... and lovin' life........MOST of the time.
DaGrinch is offline   Reply With Quote
Old 06-01-2016, 06:29 AM   #4
cpaulsen's Avatar
Just installed a Honeywell in our 5th wheel and took out the Dometic that was there...it is really close to about 1 degree for heat and cooling.
cpaulsen is offline   Reply With Quote
Old 06-01-2016, 09:52 AM   #5
2012 Solera
[QUOTE=I can deal with the fan still running when the a/c hits the proper temp. But, those cool swings...... hard on the old man! [/QUOTE]
Dometic temp swing is adjustable. See page 7 :
http://www.dometic.com/QBankFiles3/E...nual_17590.pdf
FYI
JLeising
2012 Solera "S"
Calif SF Bay Area
Old 06-01-2016, 05:14 PM   #6
nodrawers's Avatar
Thermostat replacment
I replaced the thermostat with a digital and couldn't believe the diff in temp control. Just like home. Many thread on Facebook how to do it.
Tom & Laura USAF Ret Smsgt
1995 2500 5.9 Cummins 5 sp 3.54 diff
2011 Coachman Catalina 22FB
Days Camped 2016 91, 2017 110
nodrawers is offline   Reply With Quote
Old 06-01-2016, 05:40 PM   #7
Old Camping Squid
Eagle-751's Avatar
X2. I install the Honeywell Digital and the heat / AC stays within 1 degree.
The old slider unit, the wire hookup for new thermostat ( you don't use two old wires if you don't want the two speed fan option ) and new digital unit.
ID:	109811   Click image for larger version
ID:	109812   Click image for larger version
2006 F150 Supercab 5.4 Flex Fuel
2006 BRP Outlander XT
2009 Forest River Salem 30QBSS
2005 Club Car President
2002 Ezgo Limo, 2001 Ezgo
Eagle-751 is offline   Reply With Quote
Old 06-01-2016, 06:01 PM   #8
Old Camping Squid
Eagle-751's Avatar
Just in case you can't see the details in the picture, ( this is my 2009 Forest River Salem 30QBSS, I do not know if your unit color code is the same as mine. ) On my QBSS the old thermostat had:
+7.5 = RED
Cool = Yellow
Furnace = White
High Fan = Blue
Low Fan = Brown
Ground = Green
Wires to Digital are:
B and O are only used for heat pumps. I did not use...
G = Brown for low speed fan
Y = yellow for AC unit
W = White for Furnace
R/RC is jumped together and stay that way it is for the GROUND Green wire.
The Camper has two wires not needed ( unless you want the two speed fan, in that case you will use the Blue wire ) The RED +7.5V is not needed or used at all. Blue wire or Brown wire needs to be hooked up for fan speed. I only used the low speed and hooked up only low speed.
I have used this Thermostat all year, summer and winter, it works for me and stays within one degree.
I hope this will help you and I hope your wire color code is the same. It's a real pain in the butt to figure it out if nothing matches. My Yellow and White wires are the only standard wire colors. Took my a long time to figure it out. Good Luck.
Old 06-01-2016, 07:11 PM   #9
DaGrinch's Avatar
FYI
I thank you!
But, if my t/stat only has a 2 degree differential (at most), I must have p-$$ for blood! However, I will change it to a 1 degree differential.
Old 06-01-2016, 07:16 PM   #10
DaGrinch's Avatar
Sorry, Sarge, I don't do FaceBook. Which t/stat did you replace yours with?
thermostat, upgrade
