Old 08-03-2015, 12:34 PM   #11
I have a 32' Sunseeker the A/C will freeze you out. Of course we set A/C in house at 80 and run ceiling fans constantly.
Myrle is offline   Reply With Quote
Old 08-03-2015, 12:53 PM   #12
Boso's Avatar
50 amp in rv is Not 220 it is 110 volt
i2015 sunseeker 3050s. 2007 saturn aura
Boso is offline   Reply With Quote
Old 08-03-2015, 12:57 PM   #13
TURBS's Avatar
Correct!
2 110v legs of 50amp variety!
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "24 nights"
Old 08-04-2015, 12:14 AM   #14
The 50amp plug is 2 hots a neutral and a ground. Across both hot legs is 240volts. Each hot leg to neutral is 120volts.
That is why at the power pedestal the camo site is being fed with a 2 pole 50amp circuit breaker.
barrie1 is offline   Reply With Quote
Old 08-05-2015, 12:20 PM   #15
Our 1989 Winny Chieftain had 2 ACs and 30 amp service. It had a selector switch so you could only run 1 when plugged in, both on genset.
Frank & Brenda
Thor Windsport 27K TST 507 Tire Monitors
2012 Jeep Liberty Limited Jet 4X4, Hopkins TOWD light wiring
FrankMor is offline   Reply With Quote
Old 08-17-2015, 06:38 AM   #16
TURBS's Avatar
Got my a/c unit!
13.5k brisk air II
Also purchased a 30 amp bulkhead receptacle at the goshen rally.
Ordered and waiting for the inside non ducted control panel / air defuser and 12/2 wire with ground.
Install coming soon.
I'll start a new thread with install as to not muddy this one up.
TURBS
2011 32bhok Sabre
Old 08-17-2015, 07:33 AM   #17
avolnek's Avatar
Originally Posted by TURBS View Post
Got my a/c unit!
13.5k brisk air II
TURBS
2011 32bhok Sabre
Mind sending me some part numbers you decided on?
make sure you wake me up when you do you mod thread! Excited to see how yours turns out!
I was looking in mine a week or two ago and I've got nice aluminum bracing in front of an behind my opening. Figuring my route for wires is going to be the time consuming part... also debating whether i want to go with a wall mounted thermostat or not...
TV- 2015 Ram 2500 CCLB 6.7 Cummins 3.42 gears
Camper - 2015 Saber 322BHTS
avolnek is offline   Reply With Quote
Old 08-17-2015, 07:34 AM   #18
TURBS's Avatar
I'll send you a link to the new thread shortly.
TURBS
2011 32bhok Sabre
replacement, roo, roof, upgrade
