Old 05-23-2013, 03:16 PM   #1
Sunseeker 2500TS owner
Using RV LP for portable grill?
Is there is an easy solution to using the RV LP supply for a portable grill?
I am very new at this, recently bought a FR Sunseeker 2500TS, our first motor home or RV.
Dealer I went to yesterday sold me a couple fittings to connect to the 2500TS LP supply to our Coleman roadtrip grill. I did not have the 2500TS with me, so took his word it would work. In looking at connections on the 2500TS, see no way it will work.
The fittings are a T fitting and a hose to the Coleman.
The fittings do not match up. Did I get the wrong fitting or is this not possible?
Any help is appreciated. Thank you
Emory in Maryland
ejkkj is offline   Reply With Quote
Old 05-23-2013, 03:21 PM   #2
You'll get lots of help here-people a great about that. But yes it's possible we do it all the time but DH isn't here to give specifics.
jmswms is offline   Reply With Quote
Old 05-23-2013, 03:35 PM   #3
daydreaming about camping
jeeplj8's Avatar
There is more than one way to do this. A simple kit can be put in line at the propane bottle to do this like this one:
Camco 59103 RV Propane Brass Tee with 3 Ports and 12' Hose : Amazon.com : Automotive
Or you can T the line at a more convenient place. You probably just need to take the unit into the dealer to find which fittings you need based upon where you want the line to go.
2013 Coachmen Freedom Express 320BHDS pulled by a 2005 F250 King Ranch CC
A rainy day camping is better than a sunny day at work.
jeeplj8 is offline   Reply With Quote
Old 05-23-2013, 03:43 PM   #4
Grizzlygibbs's Avatar
The problem with the Coleman Roadtrip is that the propane connection has its own regulator. There are kits you can get that would allow you to hook up to a refillable propane tank. However, this will regulate the propane flow twice and you will likely not get enough flow.
I would suggest visiting a propane distributor who specialized in propane and propane accessories who may be able to appropriately adapt from the fitting on the back of your grill to a quick disconnect.
I am guessing something such as this, then remove the regulator which looks to be threaded onto the pipe
Coleman® Replacement Camp Stove Pressure Regulator, Pipe, and Valve | Bass Pro Shops
to something like this, that will allow you to attach to your quick detach system
Amazon.com: Mr. Heater F276821 Propane or Natural Gas Male Full Flow Plug: Everything Else
Good luck
Grizzlygibbs is offline   Reply With Quote
Old 05-23-2013, 03:55 PM   #5
Denver, CO
garbonz's Avatar
I carry a separate 10 lb tank. That I connect to my propane lantern, heater and grill, as necessary. And it's a backup for my other tanks. I did already have it so it was sitting around, no expense.
My current camper has both tanks on the drivers side and I didn't want to break into the iron pipe that runs on the curb side.
2017 Fuse 23T
Old 05-24-2013, 09:50 PM   #6
Anacortesians
After hearing a few stories that suggested that the MH propane regulator wasn't sensitive enough for the low flow rate of a Weber Q (one poster said he couldn't get the grill temp down below 600 degrees), I decided to go with a portable bottle. I got a "squatty" 10-pound bottle that has the same base ring dimensions as the 20-pounder. I got a "base stabiliser" ring from CW and bolted it down in a cargo bay. The smaller bottle snaps into that ring very securely and I'm comfortable travelling with it there.
At least, I don't have a 15' flex hose leading to the BBQ with full MH propane bottle pressure in it.
Frank and Eileen
No longer RVers or FR owners
Old 05-24-2013, 10:03 PM   #7
wneise's Avatar
Like Hank Hill?
wneise is offline   Reply With Quote
Old 05-25-2013, 05:34 AM   #8
I ordered the grill from the factory and therefore got a quick connection for the grill also. It works fine. No problems with regulating flow. Someone certified in propane repair should be able to easily provide a connection for a grill if you don't have one.
2012 Forest River Sunseeker 2300 Chevy
RvBill3 is offline   Reply With Quote
Old 05-25-2013, 07:45 AM   #9
You ordered a Coleman Roadtrip from the factory with a quick disconnect? Or are you talking about the BBQ that comes with the trailer?
2008 Toyota Tundra Crewmax Limited w/tow mirrors, 5.7L, 4.30 gears, six speed tranny, towing package, Firestone Ride Rite airbags.
2014 Rockwood Roo 233s, PI HW30-C, Equalizer 10k 4 way hitch,
Old 05-25-2013, 03:19 PM   #10
Aussie brand grill from the factory. An OK grill but not the best, however having the factory installed connection for it was worth it.
