Old 05-02-2015, 05:31 PM   #1
Frankie Z's Avatar
Valve Extenders
Looking for advice on quality valve extenders for rear tires on my sunseeker. Inside dually straight extender holds air well but is too short and I have to remove hubcap to check air and fill. Outside dually seems to loose air too often after trips (guessing angle extenders are coming loose). Any suggestions?
Frankie Z is offline   Reply With Quote
Old 05-02-2015, 06:17 PM   #2
Remove all extenders and added external tire pressure sensor system so I can watch tire pressures on the dash. Solved the leaking issue. Using this system.
Tiretech on Tire Pressure Monitoring System w 6 Brass Sensors 0 232 PSI TP7002 | eBay
13larry is offline   Reply With Quote
Old 05-03-2015, 09:12 PM   #3
I too had unstable air pressures ( always had to adjust tire pressures every time I checked them) and thought it was the extenders but could never find the problem. I carried a bottle of soapy water so I could check for leaks every time. My 2012 was one of those with recalled Michelin tires. I went with BFGoodrich (made by Michelin) as the new Michelins were not readily available. After that my air pressures always are spot on and stable rarely requiring adjustment.
ATVer is offline   Reply With Quote
Old 05-07-2015, 09:44 AM   #4
Senior Members
Butch & Lena's Avatar
I am thinking on getting this external tire pressure sensor system. Is it easy to install?
Butch & Lena is online now   Reply With Quote
Old 05-07-2015, 10:36 AM   #5
Yes, just remove all extenders and attach locking nut and sensor just like a valve cap.
Old 05-07-2015, 02:02 PM   #6
jaxfl's Avatar
METAL extensions only none of those hose ones. Solid metal only.
jaxfl is offline   Reply With Quote
Old 05-07-2015, 03:31 PM   #7
So are you saying to remove the extenders then put the TPMS sensors on the original valve stem and then put the exrenders back on the TPMS ??
Kevin & Judy is offline   Reply With Quote
Old 05-07-2015, 03:45 PM   #8
geezer with gadgets
757Dave's Avatar
^^^Following^^^
Sent from my Atari 2600
2011 Sunseeker 3170ds "Ladybug"
2017 Jeep Grand Cherokee TOAD
Days camped 2015: 37; 2016: 66; 2017: 86 2018: 48
757Dave is offline   Reply With Quote
Old 07-01-2015, 01:21 PM   #9
Retired
Sorry, I am still confused. I was under the impression that you had to put straight metal valve extenders on the inner dual wheels and then curved ones on the front wheels and on the outside duallys. Then put the tire monitors on. The valves (not extenders) on our outside wheels do not allow enough room to put the monitors on them. Then the question is, what degree of angle of extenders do you order, 130, 180, etc. now you see our dilemma. We want to install a tire monitor system but no one can tell us what degree angle of extender to order for our 2012 Sunseeker.
tennlady is offline   Reply With Quote
Old 07-02-2015, 07:59 AM   #10
Hoglou's Avatar
So, these sending units attach directly to the rubber valve stem on the tire, and eliminate the extenders?
Hoglou westGA
KM4HQQ 146.640mhz
