Old 03-22-2014, 05:29 AM   #21
Hi I have a 2014 Forester 3051s and I also have horrrible to nonexistant am&fm reception. I asked my dealer and he said that they have had quite a few complaints from both Sunseeker and Forester owners. So this is not a bad antenna or poor ground problem, it is a design problem. Their only suggestion was to see if there was a more powerful antenna, aftermarket, to try. So does anyone know if something is availabe as a direct replacement that could overcome the uppercab overhang.
Sent from my SPH-L900 using Forest River Forums mobile app
USNMM1VETERAN is offline   Reply With Quote
Old 03-22-2014, 09:21 PM   #22
It's not just the Magnadyne unit. Mine came with a Jensen and as I mentioned earlier, it's not so great on either AM or FM. I have a little Sangean portable AM/FM/Weather radio that kicks the heck out of the RV radio as far as picking up stations, so I use it all time in camp.
Snowman9000 is offline   Reply With Quote
Old 03-22-2014, 09:29 PM   #23
Average Joe
MrJoe's Avatar
I noticed our antenna looks shorter than a regular van. Likely because of the front cap... I'm pretty sure it's partially explains the reception.
Joe and Karen
2014 Sunseeker 2450sf
Southern Maryland and Beyond!
MrJoe is offline   Reply With Quote
Old 03-23-2014, 11:32 AM   #24
GM
bclemens's Avatar
We use the stock Ford antenna. Just make sure it is screwed in tightly. At shows, when its slow I like to unscrew them and use them as a sword. Maybe I was distracted and left a few loose.
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
Old 03-24-2014, 07:41 PM   #25
Average Joe
MrJoe's Avatar
Antenna was tight, but there was some cotton candy on it. Must have been some party Mr. C
Joe and Karen
Old 03-26-2014, 07:47 AM   #26
Understanding the design and placement of the antenna is problematic with class C MH, the overarching question is what is the best way to improve the reception?
DrJMB is offline   Reply With Quote
Old 03-26-2014, 07:54 AM   #27
Best way to solve the problem is to hook up to satellite radio.
TomG is offline   Reply With Quote
Old 03-26-2014, 08:11 AM   #28
x2
2012 Forest River Sunseeker 2300 Chevy
RvBill3 is offline   Reply With Quote
Old 03-26-2014, 10:41 AM   #29
In class C units, the cab over is the problem with the cab fender mounted antennas. Before I purchased my 2860DS with the specially ordered cab antenna to be placed on the coach roof during the build, I had a 2300 with the identical problem. I experimented with the stock fender antenna placement. Moving it away from under the cab over made a big improvement, hence my special order to put the antenna on the coach roof on the 2860.
KQ2N is offline   Reply With Quote
Old 05-14-2014, 03:37 PM   #30
I have similar poor radio reception on our 3051 & Magnadyne radio. Sometimes can't even pick up WJR 760AM 30 miles north of Detroit! I've concluded that the problem is caused by fender-mounted antenna being shielded by the class C cab. The outside radio works much better (roof-mounted antenna). I purchased a "Y" adapter antenna cable and plan to try tapping the vehicle radio into the roof-mount antenna. Not sure how to route the cable between the O/S radio and the vehicle radio.....a project for summer!
dcogs15 is offline   Reply With Quote
radio, reception
