Old 03-11-2014, 08:28 AM   #1
Very poor radio reception
I have a 3050s with the fender antenna and I get horrible reception. Is there a alternative to replace the antenna? Add one on the roof would seem logical but a impossible to imagine how to wire? Any thoughts?
DrJMB is offline   Reply With Quote
Old 03-11-2014, 10:17 AM   #2
I have a 2014 and the radio is the same. The biggest problem is constant scanning. I very seldom use it. I'm not sure what I'm going to do either. I think some of the problem is the front overhead. Also I don't want just anyone drilling a hole in the roof for the antenna.
Bednarski1 is offline   Reply With Quote
Old 03-11-2014, 10:24 AM   #3
2013leprechaun319dsf's Avatar
Are you talking of the dashboard radio or an I house radio? I was surprised when I went on the roof of my class C and found a radio antenna for the house radio inside.
2013leprechaun319dsf is offline   Reply With Quote
Old 03-11-2014, 10:25 AM   #4
Meant to say the antenna was laying down so you couldn't see it from ground level.
Old 03-11-2014, 10:48 AM   #5
Yes dashboard radio. I thought there was a roof antenna but with the poor reception I doubt it is attached to dash
Old 03-11-2014, 04:06 PM   #6
Displaced2's Avatar
Check settings. Make sure traffic notification is turned off.
Displaced2 is offline   Reply With Quote
Old 03-11-2014, 05:17 PM   #7
Yes it's off
Old 03-11-2014, 05:38 PM   #8
I think the antenna you saw lying down is for your outside radio. Mine was.
markangie24 is offline   Reply With Quote
Old 03-11-2014, 05:45 PM   #9
That would explain a lot. There could be a way to add a splitter and run to the cab radio.
Old 03-13-2014, 04:38 PM   #10
Are you referring to AM or FM reception? Class Cs are notorious for poor AM reception due to the cab-over blocking AM reception. I had FR put the antenna on the roof for me. I got the idea from the fact FR puts the Solaris antennas on the roof.
KQ2N is offline   Reply With Quote
radio, reception
