Old 12-22-2013, 11:25 AM   #11
Originally Posted by bclemens View Post
The best way is directly into the satellite receiver and from there use HDMI or composite cables directly to the TV you want. Then instead of turning on channel 3, it is just a different source. (AV1, HDMI 1, etc). Then you can use the audio out on the TV to feed it through the stereo. Unless if course you're talking about a bedroom TVů
That was my thought - at least to get the best picture but I didn't mention because it seems as though he wants to be able to share the satellite signal to all of the televisions.
You can move the satellite receiver near the main television that you want to use and use the internal coax to deliver the satellite dish signal from outside to inside to the receiver. It will take some extra configuring at the switch box; splicing the coax needed off the switch box (essentially bypassing the switch box).
bgilly is offline   Reply With Quote
Old 12-22-2013, 11:39 AM   #12
NCIC105's Avatar
We changed the cable in on the splitter to Sat in...I use the external cable hook point to attach the sat cable.
NCIC105 is offline   Reply With Quote
Old 12-22-2013, 05:08 PM   #13
NCIC105's Avatar
Let me clarify this
We changed the cable "IN" on the splitter to Sat "IN"...I use the external cable hook point to attach the cable from the dish.
It runs dish to cable "IN", to sat receiver. Out of received, to sat "IN" on switch box.
satellite
