Old 12-21-2013, 03:47 PM   #1
NCIC105's Avatar
Volume using satellite
When we hook up our directv satellite, we get a great signal strength but the volume in so low we have to turn the TV all the way up. If the air comes on you can't hear TV well as volume is not as loud as it should be.
We have a sat inlet and utilizing the switcher that came with our 2013 3050S.
Same on front, back and outside TV's.
Anyone have an idea?
NCIC105 is offline   Reply With Quote
Old 12-21-2013, 04:44 PM   #2
litgrep's Avatar
What input of the tv are you using? If it's coming from the a/v amplifier your volumn is controlled by that.
litgrep is offline   Reply With Quote
Old 12-21-2013, 06:41 PM   #3
NCIC105's Avatar
It will only work if the TV is put to channel 3
Unless I'm missing something...
We ran it to Sat in on the switcher
Old 12-21-2013, 11:31 PM   #4
You are using the satellite box - correct? I know some s-boxes have an audio control on them that you have to adjust. At least my older box did and when I powered it off I had to use the remote to run it back up.
Check too that you are in the correct input connection to the Magnadyne switch; either cable TV, AUX 1 or 2, not the antenna one - that one is amplified in the switch.
Bobby
bgilly is offline   Reply With Quote
Old 12-22-2013, 06:55 AM   #5
NCIC105's Avatar
I'm using one of the newer sat boxes..No volume adj....We are hooked it up to the park cable as we never use the cable....
Old 12-22-2013, 07:09 AM   #6
I complained to many folks about this exact problem. The bottom line is that this has been a known problem to Directv for several years and supposedly because the number of units in the RV world
are minimal, they choose to do nothing about it.
Bob & Sue Rowan
Okeechobee, FL
2012 Coachmen Mirada 29DS (SOLD)
2015 Keystone Bullet Travel Trailer
2016 F-150 Lariat with Auto Trailer Backup
Dog = Morki (Yorkie-Maltese) - Zoe
Malabarbob is offline   Reply With Quote
Old 12-22-2013, 07:33 AM   #7
Ford Idaho's Avatar
This would be more than enough reason for me to buy another system and tell everyone I know to do the same.
I would trash talk them till the sun turns blue.
Old 12-22-2013, 08:04 AM   #8
Try straight connection to one of your televisions. The switch box might be modulating the digital audio mix.
Also, if your s-box has RCA output, connect to the switch using the one the Magnadyne DVD plugs into (although it does modulate that input too).
I have to take my unit in for some warranty work. Mine has a faulty switch box. The rear bedroom TV selection doesn't work.
Old 12-22-2013, 09:33 AM   #9
litgrep's Avatar
Am I understanding, your satelite antednna output is connected to your tailer cable input? If so that could be the problem. The splitter on the antenna amp doesn't have the bandwidth for the satelite signal. Go directly to the satelite box
Old 12-22-2013, 09:49 AM   #10
GM
bclemens's Avatar
Can you diagram your set up? If your direcTV feed just hooks into the park cable (outside of the rig) and then from there into the switch box, from switch box to TV, there is a better way.
The best way is directly into the satellite receiver and from there use HDMI or composite cables directly to the TV you want. Then instead of turning on channel 3, it is just a different source. (AV1, HDMI 1, etc). Then you can use the audio out on the TV to feed it through the stereo. Unless if course you're talking about a bedroom TV…
In my experience, something designed to cover EVERYTHING (switch boxes and Obamacare for example) doesn't really do the best possible job for one specific situation. It's designed to be too generic.
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
satellite
