Old 05-13-2013, 12:40 PM   #1
Mike & Molly's Avatar
Question W/H Tank
Just returned from our 1st camping trip in our new
Sunseeker 3010DS.
Our next trip isn't for 3 weeks.
My question is:
How long can you leave the hot water tank
full with water without having to drain it.
For those 3 weeks the RV will be in storage.
Thanks for any info.
Mike & Molly is offline   Reply With Quote
Old 05-13-2013, 12:42 PM   #2
Rugged Brown's Avatar
I keep mine filled all camping season. May - October
Terry/Bernadette
Lily the Yorkie
2015 Dodge Ram Sport 1500
Trying to resist the urge to buy another camper
Rugged Brown is offline   Reply With Quote
Old 05-13-2013, 01:03 PM   #3
TURBS's Avatar
Opposite of rugged brown I drain mine after each use.
If I don't I get a sulfer smell.
Turbs
Old 05-13-2013, 01:11 PM   #4
Gripper's Avatar
If I am not going back out within a couple weeks I drain, not sure why maybe this will help with corrosion as years go by. Make sure your water heater is off ( Electric and or gas).
Essex County
Southern most area in Canada
2017 F250 Lariat 6.7superdutyTurbo Diesel
2011 Flagstaff classic 31.5'BHDS
Gripper is offline   Reply With Quote
Old 05-13-2013, 01:27 PM   #5
Taylorgso's Avatar
I always drain at the end of the trip. Opening the access door to drain reminds me to turn off the electric heating element if it was turned on. By the way - be careful draining HOT water (learning by experience)!!!
Ed (N4RWU) & Becky Taylor
Mistie (Walks 4-down)
Greensboro, NC
Taylorgso is offline   Reply With Quote
Old 05-13-2013, 01:47 PM   #6
JeffMc's Avatar
I drain mine when I winterize. Much may depend on the quality of your water source, and how often you use it. If I had odors with the water then I might drain it after use. But since the question is "how long can I", then it can be left in until winterization.
Jeff and Dana McCreary
2004 F-250 SuperCrew Lariat 6.0 Diesel
2003 Cardinal 312 BH
JeffMc is offline   Reply With Quote
Old 05-13-2013, 01:51 PM   #7
Fulltime family RVer
Same as JeffMcCheese. I fill it up at the beginning of the season and empty it at the end. I'd change my tune if I cracked it open and it tasted or smelled bad.
Old 05-13-2013, 02:17 PM   #8
Denver, CO
garbonz's Avatar
Turbs
My previous camper did smell of sulfur for a couple of years. But only on electric. Then it just stopped. Don't know why.
I drain my tank NEVER. As it sits in heated storage and I use it. I do pull the anode annual and glance at it but I've never had to replace one. Must be that Rocky Mountain Spring water.
2017 Fuse 23T
