Old 04-15-2015, 10:10 AM   #21
GM
bclemens's Avatar
It's not really in an area of stress (like corners where the cap is attached). First glance it does look like some sort of impact...but I'm no expert on fiberglass.
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
Old 04-15-2015, 10:29 AM   #22
rsscully's Avatar
Nor am I. It is a hard pill for me to swallow that the denial was based solely on a photograph, without a rep of some sort seeing it in person. Seems like an easy out for FR to have me claim this on my insurance.
rsscully is offline   Reply With Quote
Old 04-15-2015, 10:37 AM   #23
GM
bclemens's Avatar
Well, they would also go off of info from the dealer as well.
With about 8,000 units in the field with that cap and this is the first one we have seen like that, I'm not so sure its an easy out as much as it is an reasonable deduction. I'll ask our fiberglass guy if they have seen anything like this...but again, it has the tell tale signs of impact.
Old 04-15-2015, 03:07 PM   #24
jaibyrd's Avatar
Originally Posted by yvonthe1 View Post
The tires monitor is TM66**ô Series TPMS - Technical Support is hawsome. Get them they will save the day, and will make you life easier
The weight I had concern at first, weight the unit when new empty, just full fuel. And loaded it from there, we are 2 adult 2 kid
Yes it was a concern we've adapted
What are the brand of your hydraulic jack and where the control are located
I will install them, but needs more info and if you have any pictures on how and where each jack are mounted and the control
I will take mine for a spin this weekend the kids and I just can wait
Regards
Yvon
I'll be looking into the TPMS for sure. Will post some pics when I get the unit so you can see the levelers. My unit just came off-line and should be in paint now. We are thinking I should have it in a few weeks.
Snyder Family - Pelham, NH
2015 Sunseeker 3170DS
jaibyrd is offline   Reply With Quote
Old 04-15-2015, 08:19 PM   #25
BamaGrad's Avatar
A couple of questions about your TM66 on the 3170DS:
1. Did you have solid one-piece stems aded?
2. Did you have issues with the sensors "fitting" in the slots of wheel inserts?
I can barely get a air chuck on my stems through the slots in the wheel inserts. I really want to get a TPMS but am worried about the sensors fitting.
R & J
2007 Ford Escape Toad-5 spd manual
Blue Ox Alpha tow bar/Blue Ox Patriot brake
47 nights camped 2017, 41 nights camped/booked 2018
BamaGrad is offline   Reply With Quote
Old 04-15-2015, 11:43 PM   #26
Yvonthe1
yvonthe1's Avatar
Well the whole thing started on my trip
I notice my rear right tire was low on air, and had the tire remove and re install they did find the leak, finally it was the stem valves extension made with plastic, son I replace them all, and install the tpms66
And it save time on my checklist prior to departure and safer
yvonthe1 is offline   Reply With Quote
Old 04-15-2015, 11:45 PM   #27
Yvonthe1
yvonthe1's Avatar
Also the sensor fits well in the well, with the proper valve extension they fit on properly and easy access even the inner tire
Old 04-15-2015, 11:50 PM   #28
Yvonthe1
yvonthe1's Avatar
An other thing I have on the new one, I replace all the bulbs to led, and get this they came from Home Depot they have them only in the usa,made by Philips and draw less amp and stay cold, the one with filament would probably over time melt the support and lense
I will try to put pictures of themClick image for larger version
Name:	ImageUploadedByForest River Forums1429160089.770760.jpg
ID:	74374Click image for larger version
Name:	ImageUploadedByForest River Forums1429160107.723455.jpg
Old 04-17-2015, 09:36 PM   #29
Yvonthe1
yvonthe1's Avatar
also I have added top hat mirror from velvac,not only they look good, it makes the driving with a better view when passingClick image for larger version
Name:	ImageUploadedByForest River Forums1429324850.523154.jpg
ID:	74553Click image for larger version
Name:	ImageUploadedByForest River Forums1429324873.250016.jpg
Old 04-18-2015, 10:22 AM   #30
geezer with gadgets
757Dave's Avatar
[QUOTE=yvonthe1;838598]also I have added top hat mirror from velvac,not only they look good, it makes the driving with a better view when passing
Those look like they really help with driving.
Where did you purchase these? Were they difficult to install? A link for online? Thanks for sharing.
757Dave
Sent from my Atari 2600
2011 Sunseeker 3170ds "Ladybug"
2017 Jeep Grand Cherokee TOAD
Days camped 2015: 37; 2016: 66; 2017: 86 2018: 48
757Dave is offline   Reply With Quote
