Old 04-02-2016, 04:09 PM   #1
Washing an RV is a lot like work...
In fact, it is work.
Got the RV washed today and realized it is supposed to be white. Sitting over the winter it had started to turn grey. BTW, what do you use to clean the black streaks? Dawn did pretty good with some scrubbing but doesn't get it all over. While we were at it, we vacuumed and mopped the interior and did some restocking.
On a good note, I had the propane topped off as it was at half a tank. The meter didn't run so the guy who topped me off didn't charge me as he didn't know how much he put in. I told him to charge me for a half tank and after a couple minutes of discussion he still wouldn't charge me.
2014 Sunseeker 2860DS
gmacklem is offline   Reply With Quote
Old 04-02-2016, 05:55 PM   #2
It is a heck of alot of work. Every time I do the roof I swear I never want a longer camper.
Old 04-03-2016, 02:06 PM   #3
Delco Bobby's Avatar
Probably not the best choice but I used simple Green on the black streaks and they wiped off easily. I got sick of looking at them but the simple Green may affect the wax.
2017 Dynamax REV 24RB
2018 Ford F-150
Delco Bobby is offline   Reply With Quote
Old 04-03-2016, 06:22 PM   #4
I use car wash by zip wax Don't want the decales to fade
retired on a mountain is offline   Reply With Quote
Old 04-03-2016, 06:34 PM   #5
Flybob's Avatar
Best way to make washing easy is to use a good wax/finish. I use Meguiar's NXT generation tech wax 2.0. It is a polymer and holds up very well The best part is you can wax the entire RV and wait hours and the haze wipes off like dust. Black streaks wash off easily. One caution. do not use a power washer ( some dealers do). Careless use of a PW can lift caulk and decals very easily.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 04-04-2016, 09:40 AM   #6
Total Loss's Avatar
As Flybob says...
A good wax (as painful as that chore is) will help the finish tremendously and makes the rig easier to clean.
The front and rear caps require this more often due to the weather beating they take.
I rarely use water on the rig.
Localized portions only and an undercarriage splash after dirt roads.
If you are diligent in wiping the rig off with a wet towel after every trip- the deep cleaning is minimal.
Then of course I cover mine since I am a clean freak.
(I use Mothers Carnuba cleaner wax- red bottle)
"If you are going through hell..keep going"
W. Churchill
Total Loss is offline   Reply With Quote
Old 04-04-2016, 09:44 AM   #7
Blacknchromehd's Avatar
Rinse Kit
I use a product called Duragloss...its a sealant instead of a wax...but my RV has 4 coats of clear...many are different finishes...what I do use is this Rinse Kit I bought at Hershey last fall...its amazing to use ...I have used it to wash small sections at Campgrounds...on my travels I mix it with bug removal products and really easy to use...Friend used his this weekend to detail the wheels and tires...
Amazon has them...
ID:	103865   Click image for larger version
Blacknchromehd is offline   Reply With Quote
Old 04-04-2016, 10:14 AM   #8
Land of the Midnightsun
jjSpeedwagon's Avatar
I'm washing ours for first time. Got it washed yesterday and went well. I washed and my wife rinced not sure why but I was soaked to bone when we got finished anyhow waxing this morn and yes it's a chore. Finish one side and I'm using that Lucas slick mist speed wax and it does pretty wellClick image for larger version
John & Janice
2016 Coachmen Concord 300DS
2010 Jeep JK 2.5 inch lift 33' tires
Elite Ready Brutte tow bar & Blue Ox base plate
Never mistake Knowledge for Wisdom. One helps you make a living the other help you make a LIFE.
jjSpeedwagon is offline   Reply With Quote
Old 04-04-2016, 10:32 AM   #9
W5CI's Avatar
I am taking my Cedar Creek to the truck wash
2005 Cedar Creek 30RLBS/TrailAir Hitch/ MORryde 7K IS/Disc Brakes/ PI PT-50 EMS/ RV Flex Armor Roof
2015 RAM 3500 DRW 6.7 Cummins 3.42/ Garmin 760RV
40 Gal TransferFlow fuel tank/ TST 507
Amateur Radio W5CI 2017 Days Camping 77
2018 Days Camping 44
W5CI is offline   Reply With Quote
Old 04-04-2016, 10:46 AM   #10
Flybob's Avatar
Be careful. Many truck washes use power washers. They can/will lift caulk and decals. Very convenient and easy, but damaging if not used properly. Some dealers use them to prep new RV's as they are quick and easy. The problem is that they usually don't put the highest paid tech on the power washer, Probably why so many new RV's have leaks that were not there when they left the factory.
TST Tire Monitors
2 100W solar panels
