Old 10-25-2010, 09:39 AM   #1
water heater drain location
I have a 2010 sunseeker 2940 ds. the water heater sits directly above the generator. I have found a red and blue drain on the curb side and a blue drain on the drivers side next to the sewer connection. Does the one red drain the water heater from the other side of the coach or is there somewhere else I should be looking? the water heater is on the drivers side.
rivercat49 is offline   Reply With Quote
Old 10-25-2010, 10:14 AM   #2
Head Rambler
The water heater is usually drained by removing the plug behind the outside access panel. Depending on whether it a Attwood or a Suburban it'll either be a plastic plug or a anode rod right near the bottom of the tank.
Gotta go campin!
Bama Rambler is online now   Reply With Quote
Old 10-26-2010, 01:35 PM   #3
Thanks my previous camper had a seperate drain under the camper for the hot water tank. I wanted to make sure i wasn't missing something.
sunseeker le
