Old 06-13-2014, 11:46 AM   #1
water in side storage
I am getting water in the driver side storage compartment under the hot water heater . It looks like the whole compartment is sweating and then condensing. Is this a common problem? Is there a cure for this?
2014 sunseeker 3170dsf V10
cruiserjohn is offline   Reply With Quote
Old 06-13-2014, 02:34 PM   #2
The sweating is probably a symptom of a leak. Water gets into the compartment and condenses on the walls due to temperature changes. As long as it isn't raining, dry out the compartment and leave the door open. Wait a while and see if it is a plumbing leak from the water heater or something.
ATVer is offline   Reply With Quote
Old 06-14-2014, 01:55 PM   #3
The water heater safety relief valve will weep and drip a little. It will run down onto the compartment door seal and can leak into the compartment. With changes of outside temperature the water can evaporate, then condense on the compartment walls. Check your compartment door seal.
It is normal for the relief valve to weep a little now and then. The water expands as it is heated. If all of the faucets are closed, the relief valve will weep to keep the pressure from going over 150 psig. On our Sunseeker, when this happens it's almost impossible to flush the toilet without opening a faucet first. If you ever have a stuck thermostat the relief valve will pop fully open at 150 psig, then reseat when it gets back to a safe pressure.
Old 06-16-2014, 07:58 AM   #4
Cruiser, my hot water heater under the sink was dripping. Had
the dealer correct this problem.
Phelpo
phelpo is offline   Reply With Quote
storage, water
