Old 08-21-2016, 10:13 PM   #1
Water in Storage
I have a 3170 sunseeker MH and noticed puddle of water in the storage area to the left of the door (under the refrigerator area). This only happens when it rains and when I did a visual inspection, couldn't find any water under the fridge area. Also, when I rub the top surface of the storage, I could feel the water (like a damp layer) on top.
Any help to troubleshoot the source of water and fix it?
thanks
Venkat
vriyer is offline   Reply With Quote
Old 08-21-2016, 10:54 PM   #2
flymhi's Avatar
was the last rain a blowing rain? It sounds like the water is entering though your fridge vent on the roof.
2015 Denali Duramax 2500
2017 Coachmen 229TBS
2010 Shamrock 21SS - sold!
flymhi is offline   Reply With Quote
Old 08-22-2016, 05:37 AM   #3
Check the storage compartment door seal. Lay strips of paper on the seal, and close the door. Pull on the strips. If strips come out easily, the seal isn't tight. You may be able to close the gap by bending the place where the latch tab strikes.
RamblerGuy
2011 Sunseeker 3100
1997 Pathfinder Toad
Old 08-22-2016, 07:37 AM   #4
geezer with gadgets
757Dave's Avatar
thanks
Venkat
I have the same MH as you and had water in the same storage compartment. Checked everything to see where it was coming from and determined that the seal on the compartement door was not sealing properly. Purchased new seal material from local RV store and haven't had a problem since. Good luck!
Sent from my Atari 2600
2011 Sunseeker 3170ds "Ladybug"
Days camped 2015: 37; 2016: 66
757Dave is offline   Reply With Quote
Old 08-22-2016, 12:21 PM   #5
I had 2 water in a storage compartment and found the latch was not quite tight. On another I found a hairline crack in the lap sealant along the top of the trim for the hatch. I added some more lap sealant and haven't had it leak since. I did a video of the work if you want to see it:
https://youtu.be/CbOJ_D3TrvE
2014 Sunseeker 2860DS
gmacklem is offline   Reply With Quote
storage, water
