have a water leak on the connection to the water pump from the holding tank. seems to be a slow drip, but dry camping water is important. do you hand tight, or but more pressure on it. unit is only 6 months old, so maybe take it back to dealer to be fixed thanks oldnewguy
If its not a crimped connection should be able to hand tighten. I find in many cases there is a bur or something, so might need to disconnect, make sure its a clean fitting and reconnect.
__________________ If "Search this Forum" does not yield answers, please post questions as a "New Thread" (instead of asking privately) so others can benefit from the answers.
the leak is from a connection that has a wire screen in it, i have tried to tighten it but the space is very small. a very slow leak , that will empty the tank over time. i will let the dealer deal with it
That's the inline screen filter to prevent water pump damage. May be a bad part.
