Old 07-21-2014, 05:00 PM   #1
Mike & Molly's Avatar
Water Pressure Regulator
Does anyone know the max city water pressure a Sunseeker can handle with out doing damage.
Thanks.
Mike & Molly is offline   Reply With Quote
Old 07-21-2014, 06:28 PM   #2
150 psig. That's what the water heater relief valve opens at. If the water heats up when no water is being used the expansion will raise the pressure until the relief valve starts to weep. That's less than 150 but close. It happens often with us and never had damage.
RamblerGuy
2011 Sunseeker 3100
1997 Pathfinder Toad
Old 07-22-2014, 08:40 AM   #3
Thanks for your input.
I was referring to the max. pressure of the plumbing inside the RV can handle. (pipes & connections)
Water pressure at campgrounds vary greatly, so I purchased a regulator that attaches to the campground site water supply.
Looking for a safe max. setting to use.
Old 07-22-2014, 08:54 AM   #4
bend302's Avatar
While there are lots of opinions on this subject, I set my adjustable at 50psi and have plenty of water pressure and have had no issues.
Bill
Life is a journey, not a destination.
2005 Georgetown 359ts
Bill & Virginia, Kentucky
Nights camped in 2011...78 , 2012...73,
Nights camped in 2013...123, 2014 ...101
bend302 is offline   Reply With Quote
Old 07-22-2014, 09:55 AM   #5
The entire cold and hot water systems are at the same pressure as the water heater. The fresh water pump and city water connections have check valves so high pressure in the coach plumbing does not push water backwards.
50 psig is a good setting but the system can and does experience 150 psig.
RamblerGuy
2011 Sunseeker 3100
pressure, water
