Old 08-02-2016, 10:42 AM   #1
water problem
Have a 2013 3050s sunseeker, this weekend while hooked to city water, my freshwater tank filled. i know this is a problem that was in a thread before , just can not find it. should be a back flow valve stuck open or broken, just need to know location of valve. thanks in advance for a response
oldnewguy is offline   Reply With Quote
Old 08-02-2016, 10:51 AM   #2
The check valve is usually part of the pump. Replace pump ($$) or 1) find new parts for old pum, 2) add a 2nd check valve on the suction of the pump, or 3) add a ball valve on the suction of the pump. (Check valve if you use the FW tank a lot. Ball valve if you don't.)
1988 Coleman Sequoia - popup (1987-2009)
2012 Roo19 - hybid (2012-2015)
2011 Traverse LT, 3.6L, FWD
2009 Silverado Ext Cab, 5.3L, 4x4, 3.73
Old 08-02-2016, 10:52 AM   #3
It will be just after the water pump and before the fresh water system ties into the city water connection.
Here is a link to a typical RV plumbing diagram.
http://www.forestriverforums.com/for...3&d=1469457186
ShermanD is offline   Reply With Quote
Old 08-02-2016, 10:55 AM   #4
Flybob's Avatar
Shut off city water
Make sure water pump is off
open faucet
turn on water pump
let water run for a minute
shut off faucet
wait until pump stops.
Shut off pump
turn on city water.
This should reset the back flow valve
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 65W solar panels
Old 08-02-2016, 11:25 AM   #5
Witch Doctor's Avatar
X'S 2 on fly boys comment, I have used that about 3 different times, It seems that if my pump is on by mistake and I turn the city water on is when it happens to me, that's all I can figure out, but what Flyboy say's will fix it if you do not have a diaphragm problem....
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
water
