Old 10-05-2014, 04:38 PM   #1
Water pump
Rookie here again with a question about the water pump. Taken 2 trips so far, both dry camping. Friend of mine with an rv told me not to leave the water pump switch on unless I actually needed to use it, said it was not good. Is this true or can I leave he pump on? I worry some of my guests forget to turn it on/ off and don't want to do any damage.
Thanks everyone who has been helping me out. I have had great trips so far!!
beachbum107 is offline   Reply With Quote
Old 10-05-2014, 04:48 PM   #2
Mikegjax's Avatar
I think either way is fine. If you have the pump on and it cycles often without water demand, then I would turn it off when not in use. Cycling would indicate a leak somewhere or a check valve not working properly.
As long as is does not run without demand, I would not worry about it.
2014 Solera 24R
USN Retired
Mikegjax is offline   Reply With Quote
Old 10-05-2014, 05:14 PM   #3
camaraderie's Avatar
x2
________
Cam
2015 Georgetown 280DS
2014 Vespa LX150 2014 StellaAuto 125
camaraderie is offline   Reply With Quote
Old 10-05-2014, 06:28 PM   #4
Water pump works on demand only. Leaving the switch on is fine. However, if you are connected to city water, switch will be off.
biznsa is offline   Reply With Quote
Old 10-06-2014, 10:15 AM   #5
Mike & Molly's Avatar
Leave It On
If NOT connected to city water supply, leave the switch on. It only works when you turn on a faucet or flush the toilet. Just keep track of your fresh water level. You don't want to run the pump with no water in the system.
Mike & Molly is offline   Reply With Quote
pump, water, water pump
