Old 07-30-2013, 08:08 PM   #21
Originally Posted by Cmitchell40 View Post
Well Fellas... Sorry it's been awhile. That trip I went on? I spent the first 4 days on the phone with the dealer because, low and behold, the water pump went again, this time causing a lot of water damage in the rear of the rig. Carpet and wood underneath both soaked. Turns out the pump is faulty, check valve not working properly, which is allowing the tank to fill and with nowhere for the water to go its bursting out the hose. I am a civil engineer by trade so I understand the mechanics of back flow preventers and the like but my dealer would not replace the pump but claimed to have found a leak and so now because of it we have an even more expensive problem. The good news is that Forest River has been fantastic and willing to make things right. I can't say enough positive about their warranty dept. So... Faulty check valve required us to replace the pump and we took it to a different dealer to do all of the gutting and repair from the damage.
Kind of surprised you had water damage due to the failed check valve. I would have expected the water would just come out the overflow vent (little screened vent outside the vehicle next to the gravity fill cap) and flowed harmlessly down the outside. Something in that line must have also failed or been kinked to plug it up.
ATVer is offline   Reply With Quote
Old 07-30-2013, 08:42 PM   #22
The tank fill tube was brittle and I think it was damaged when the first dealer was "investigating" the first occurrence. The tube split in 4 locations and dumped water under bed area because it could not reach the overflow exit. A true mess.
Cmitchell40 is offline   Reply With Quote
