Old 08-15-2015, 09:26 PM   #11
Citrus County, Fl.
GL1800Rider's Avatar
It's a heavy ladder. I suggest setting it up as an A frame an not put it against the unit. The ladder is very stable.
2016 Forester 3011DS
2017 Toyota Corolla SE toad
99 Terry 31G
GL1800Rider is offline   Reply With Quote
Old 08-15-2015, 10:02 PM   #12
SAFETY FIRST
A word of advice from a guy who used ladders to make a living, 30 plus years.
Place your extension ladder against the RV (wrap a rag, t-shirt, etc. around the ladder to protect your surface) with at least 3 feet extending beyond the step on/off point. Walk up, holding on to ladder, step off. Coming down, hold the ladder against the RV, step on the ladder, walk down.
If you step on a step ladder from the roof you are asking for a fall. It is like the boat and the dock scenario, as it goes away you fall off the roof! If you must use the step ladder, do so with it folded and leaning against the RV.
BTW, at 6'4" and 230 lbs, my size 14 boots have walked/worked all over my roof with no apparent damage to anything.
Travel safe
2001 Ford F-350 Super Duty CC Dually, 7.3 Diesel
2011 Cedar Creek 36CKTS Touring Edition
FordHauler is offline   Reply With Quote
Old 08-15-2015, 10:40 PM   #13
Just a member
kandl's Avatar
Originally Posted by Campin Cajun View Post
Your ladder should have a sticker on it with its weight limits.
Ditto - we have a label on the railing near the first step. Max 300 lbs.
Keith, Lori & the Wild Bunch
TT: 2011 Rockwood 8293RKSS
TV: 2009 Dodge Ram 1500 CC 4x4 (ya.. it's got a Hemi
kandl is offline   Reply With Quote
Old 08-16-2015, 05:18 AM   #14
Buy a little giant folding ladder works great place it br beside back ladder on the RV better support going up then coming down
goots is offline   Reply With Quote
Old 08-16-2015, 05:39 AM   #15
Ford Idaho's Avatar
6 foot 215 pounds I have been on the roof a couple of times now with no worries, ladder is rated at 300 pounds on the lite.
Wear flat soled shoes and be dang careful if the roof is wet because it gets real slick up there.
Old 08-16-2015, 07:07 AM   #16
Garrette's Avatar
Originally Posted by BamaGrad View Post
Do you use it as step ladder or lean it against the roof?
I set my ladder up with the near side closest to the RV near vertical and the far leg at what ever angle is needed. With this, the ladder does not touch the RV.
Name:	ImageUploadedByForest River Forums1439726788.240400.jpg
Garrette is offline   Reply With Quote
Old 08-18-2015, 11:55 PM   #17
I have a little Giant ladder that open as a step ladder from 6ft. to 10th I places along the RV ladder to get to the roof
weight
