Old 10-12-2018, 09:47 AM   #1
Weird Faucets?
So on my 2014 SS 3010DS the hot water shower faucet opens clockwise while the bathroom cold water sink faucet also opens clockwise as well. These are opposite of what is normal. These are both integrated units, i.e., the spout, hot, and cold faucets are one unit. BTW, the shower controls are also upside down compared to my other trailers I'm familiar with. In other words, the hose assembly goes towards the bottom as opposed to the more normal top towards the shower head. The hose on my unit then wraps around the handles to go towards the shower head.
Any idea what happened here and how to correct?
2014 Sunseeker 3010DS on Ford Econoline E450 Chassis
Newly Retired!!!!
Atlanta Panther is offline   Reply With Quote
Old 10-12-2018, 10:14 AM   #2
A32Deuce's Avatar
Mine are the same in a 2012!
A32Deuce is offline   Reply With Quote
Old 10-12-2018, 10:44 AM   #3
Dcbenny's Avatar
my 2016 SS did the same got tired of cold water shock or getting scaulded switched them out to a lever style on both sink and shower works a lot better
Don & Liz B.
Pink Retired Greyhound
2016 GTS 2800QSF
Dcbenny is offline   Reply With Quote
Old 10-12-2018, 10:52 AM   #4
Sunseeker 2400MBW
Our 2016 SS is same. My husband changed BR sink to a lever faucet.
But the shower doesn’t seem that easy. After 7 months in SS I spent a week with my daughter. Her shower was such a challenge! What faucet goes on that shower?
Full time 2016 Sunseeker 2400WS towing a 2018 Subaru Forester.
Nancyc7 is offline   Reply With Quote
Old 10-12-2018, 11:09 AM   #5
Dcbenny's Avatar
I purchased them thru Amazon don't know what type pf shower you have but on mine just unscrewed the round access panel took me about 15 minutes
ID:	188982   Click image for larger version
Don & Liz B.
2016 GTS 2800QSF
Old 10-12-2018, 11:18 AM   #6
Bill and Gail's Avatar
The same in 2016DS. You would have to remove the shower faucet assembly, swap the lines and remount the assembly upside down (hose facing up) to change the direction the faucet knobs operate.
Bill and Gail is online now   Reply With Quote
Old 10-12-2018, 11:59 AM   #7
The problem then is
Although it would fix the upside down problem It will just reverse which faucet is opening incorrectly won’t it?
Newly Retired!!!!
Old 10-12-2018, 12:10 PM   #8
bob213's Avatar
Had that on a sink in my house. The cartridge in the handle was installed 180 degrees off. Pulled cartridge out and re-aligned it. Don't know if your rv faucet has ceramic cartridge but that could be fix.
You can avoid reality, but you cannot avoid the consequences of avoiding reality – Ayn Rand
bob213 is offline   Reply With Quote
Old 10-12-2018, 01:45 PM   #9
If you turn clockwise now, when you flip the assembly, it would open the hot counterclockwise, because you also swap the connections.
Old 10-12-2018, 01:47 PM   #10
You just have to make sure it will go back in, flipped.
faucet
