Old 03-04-2013, 11:12 AM   #1
Smile wet compartments
first thanks to all the people that respond to all my questions. my new question is. there seems to be a lot of moisture in the compartments under the coach. i never had this problem in my class a . moisture seems to collect in the shallow ones and not the lage ones. i live in mass very near the ocean. we have free-zzing temps at night and warm up to 40-45 during the day. some compartments have plug holes in them, should i open them. new to a class c with sealed compartments
oldnewguy is offline   Reply With Quote
Old 03-04-2013, 01:15 PM   #2
Plain Old Member
How much moisture is a lot of moisture? I had one compartment behind the rear wheels with quite a bit of water in the bottom once. After shining a light in the wheel well, I could see light through a slight crack in the sealant. As for the other bays, never had any water issues. On some, if you don't secure the center lock on the hatch, it might leak a little in the rain or traveling in the rain. Which model do you have? The heat in ours is ducted into the bays around the water tanks and black / gray dumps. Not sure how much that would matter, but that's only 2 bays.
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
BigJohnD is offline   Reply With Quote
Old 03-04-2013, 07:29 PM   #3
everything feels damp like grass in the early morning all my folding chairs were damp. my water hoses were damp in another compartment
Old 03-04-2013, 07:33 PM   #4
TURBS's Avatar
check into damprid damprid - Google Search
