Old 04-17-2015, 10:03 AM   #1
wesslvm's Avatar
What AWG is the wiring to the batteries 3050S?
Hi,
I was hoping someone already knows the answer without my having to repeat the research.
I'm installing a battery monitor with a shunt installed on the negative cable coming off the batteries.
I need to know what size wire to use to create a short jumper from the batteries to the shunt. Also what lug size?
Can anybody help? I'm guessing #4 AWG.
I'm thinking this will do the job:
http://www.amazon.com/Camco-47443-4-...WG+cable+12%22
Wes
2014 Sunseeker 3050S
Honda CRV (TOAD)
wesslvm is offline   Reply With Quote
Old 04-17-2015, 06:59 PM   #2
Can't answer your questions but I bought battery cables to modify our Boy Scout Troop bus at NAPA. They have a variety of sizes, lengths, and terminals. Other good auto parts stores should have a selection. Won't have to deal with delivery. NAPA also had terminals for soldering onto cables. This allows you to make up exactly what you need. I used these and bought cables the lengths I needed to fit the modifications I did.
RamblerGuy
2011 Sunseeker 3100
2016 Ford Edge Toad
Old 04-17-2015, 07:07 PM   #3
I just checked a deep cycle battery I have in my shop. The threaded battery posts for cable lugs are 5/16 inch diameter. Sorry but our RV is in storage so I can't check the cable conductor size.
RamblerGuy
2011 Sunseeker 3100
2016 Ford Edge Toad
Old 05-02-2015, 08:45 PM   #4
wesslvm's Avatar
Ended up going with #2 AWG and 5/16 lug which fit the battery but not the 500A shunt. Had to "hog" the other lugs to fit the shunt.
Honda CRV (TOAD)
305, 3050s, wiring, battery
