Old 10-22-2014, 06:44 AM   #1
trdutch's Avatar
What came out of my hot water tank?
This is a repost to try and get opinions from the Sunseeker crowd.
My 2860 low point HOT drain is capped under the coach next to the cold (that shuts off in line by the pump)
Road debris broke cap and I bled all my potable water out on the highway through the hot side
Question one,
Obviously all water drained is this normal through the hot drain
Question Two
What came out of the hot water tank?
The spray back discolored and stained the aluminum diamond plate and aluminum fender of my motorcycle trailer
It would not wash off it had to be polished off with Aluminum paste cleaner
White spot on driveway with rust ring
Reminds me of stain left after cleaning a corroded car battery with baking soda
The tank was filled with my homes city water
Any chemists out there?
Was this mineral deposits at the bottom of my hot tank?
I've not checked the hot tank anode yet cause the unit was new in July
I know you should periodically flush the hot tank
Did this leak do it for me
The fender and diamond plate looked like it was sprayed with opaque white paint
Any ideas, or opinions?
I never saw a Hearse towing a Trailer
'71 Dads VW camper pop up Van
'78.....tents
'93 Coleman pop ups (I'm Dad)
'04 Fleetwood Jamboree 26q
'14 Sunseeker 2860DS
trdutch is offline   Reply With Quote
Old 10-22-2014, 06:48 AM   #2
I am betting the white stuff is from the anode.
limblips is offline   Reply With Quote
Old 10-22-2014, 06:58 AM   #3
This year I (wife) had bought a little wand to help clean out the hot water tank. She thought it looked like a cool little gadget. I couldnt beleive how much stuff came out. I park in the gravel on the side of the house, and its still there 6 months later. Calcium deposit, maybe use that CLR stuff.
Tim Myers
2013 Ford F-450
2015 Sabre 34 REQS-6
2018 XLR Boost 27QRB
dustym is offline   Reply With Quote
Old 10-22-2014, 07:13 AM   #4
Plain Old Member
I second the white being from the anode. Had the same crap come out of our shop waterheater, and it was the anode. Low points can siphon the water heater. We proved that in our shop, after filling numerous 5 gallon buckets under the drains. It kept going and going, us knowing darn well there wasn't that much water in the lines alone. Pulled the water heater anode and it was almost empty.
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
BigJohnD is offline   Reply With Quote
Old 10-22-2014, 08:37 AM   #5
Brother Les's Avatar
Have you ever cleaned out a home 50 gal Electric water heater? The amount of calcium, minerals, metal flakes from the tank/rods/heating elements, chemicals for treatment of the water is very high. I have a shop vac with attachments to suck out most of this debris once a years or it will build up over the lower elements and burn it up/short it out. The calcium is flaky white and I can get most of it out. When refilling the water tank, I 'flush' and burp the air from the tank into the bath tub. There is still a lot of stirred up 'crxxp' in the bottom of the tank. Some of this consists of heavy black slime and multiple amounts of other 'junk'. I run the water into the tub until the water is clear. If you run the water first through any faucets, you will clog up the screens. Water... from water systems contain a lot more than just 'plain' water....
Brother Les
Old 10-22-2014, 08:49 AM   #6
Question one,
Question Two
I was thinking about replacing the caps with valves. Sounds like a good project for the winter.
Don't have a good answer for the damage to your trailer aluminum. One thing that puzzles me is how the broke drain line cap on the hot side could drain the water heater. The hot side connection to the water heater is on top. Even if it somehow drained any cathode debris would remain in the bottom. If it was the cold side drain then it could drain the water heater. Did you verify the water heater was actually drained?
ATVer is offline   Reply With Quote
Old 10-22-2014, 02:01 PM   #7
trdutch's Avatar
Pressure relief valve had no pressure or water when opened
System is completely empty all the way to the filter canister having an inch of water in it
I did not open the the main plug/anode
No water flows from faucets or toilet
Someone suggested that it could have siphoned its self dry
'78.....tents
Old 10-22-2014, 02:19 PM   #8
If you were going down the road with the cap off, the air going across the pipe will syphon all the water out of the entire system, it is called Bernoulli's principle which is how carburetors worked.
Old 10-22-2014, 02:54 PM   #9
Sorry but I'm still stuck on how the hot water heater would drain if only the hot side was open. Air would have to get into the system somehow. Was your water pump switch left on?
Old 10-22-2014, 04:43 PM   #10
trdutch's Avatar
Yes to Bernoulli principle (which is how an Airplane gets off the ground I might add)
Yes to pump being on while traveling to use bathroom
Empty system
You don't think I hurt the water pump?
'78.....tents
hot water, tank, water, water tank
