Old 12-14-2013, 02:17 PM   #1
What do these wires connect to?
Hi again, I just had a previous discussion on ways to easily lift the bed. So I pulled off the mattress to gain access to the box underneath, lifted the lid and found a couple of wires disconnected and just laying there. I also found 2 wire nuts on the floor. The blue and white wires go into the lid and underneath the slide but they have no power. The red and white wires have 120 Volts when connected to shore power. Not 12 volts. My assumption is they connect together, but I don't really know for sure. I don't want to connect them together without knowing. Everything works on the rig as is, power outlets work inside and out, a/c and heather works. I'm scratching my head on this. I have a 2011 Sunseeker 3120. Anyone remember seeing these wires and if they connect together? Thanks, Randy
Randy P is offline   Reply With Quote
Old 12-14-2013, 02:26 PM   #2
Ford Idaho's Avatar
Can you find the red and white wires on the power panel, if you can what is the breaker labeled as?
Old 12-14-2013, 02:58 PM   #3
Opps, voltage is 12.5, had voltmeter on wrong setting. The wire leads to the fuse box, and states: 15 amps Rear
Old 12-14-2013, 03:01 PM   #4
Just figured it out. They go to the lights above the bed. I thought the bulbs were burned out. But they work now. Thanks
Old 12-14-2013, 03:05 PM   #5
Ford Idaho's Avatar
Ahhh, very cool....
Buy some spare bulbs just the same....
Old 12-16-2013, 10:22 AM   #6
GM
bclemens's Avatar
My first thought was the flux capacitor, but the bedroom lights make more sense now.
Please READ the entire thread before posting to keep comments relevant.
Also, please post questions as a "New Thread" (not private message) so that others can benefit from the answers. Use Private Messages for sensitive information only. Owners manuals are available online and via iPhone/Android Apps.https://www.dynamaxcorp.com/OnlineManual.aspx
