Old 08-19-2014, 10:57 AM   #1
GM
bclemens's Avatar
What do you think of this prototype feature?
It's a 4 port USB charging station, with a small net to keep things out of the way.
You don't have to use the net...cord will reach to the dinette top or cup holders behind the sofa.
Just in testing phase right now.
Name:	2014-08-19 11.32.50.jpg
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
Old 08-19-2014, 11:06 AM   #2
RPAspey's Avatar
I'd like one. We're always charging something using a mess of 12 plugs & adapters.
2000 Cherokee 29BH with 6V batteries, LED lights & 400 watts of solar power, flipped axles and raised. 2007 Tundra 5.7L DC-LB with lots of mods. C-co, 8/158th AVN Maint.
RPAspey is offline   Reply With Quote
Old 08-19-2014, 11:31 AM   #3
I did something similar.Only bad thing I've found,is that it takes forever to charge the Ipad on the 5 watt USB.Takes no time on a 110v plug in with the adapter.
DaveandSue is offline   Reply With Quote
Old 08-19-2014, 11:36 AM   #4
GM
bclemens's Avatar
The issue is amperage.
iPhone uses 5 volts, 1 amp
iPad needs 5 volts, 2.1 amps.
we struggled with a lot of USB chargers because if there are (2) ports it is 2 amps combined. So (1) iPad you are good. Plug in (2) phones you are good. (1) iPad and (1) phone. No good.
This 4 port charging station we found (and decided would be most user friendly) has all (4) USB ports rated at 2.1 amps.
Old 08-19-2014, 11:41 AM   #5
GM
bclemens's Avatar
We're thinking if this works, we can get rid of most of the 12V power ports. (other than what is on the chassis).
Most people are not using a "dedicated" 12V car charger. I have a little 12V car charger plug that has (2) USB ports built in. Seems like all the new ones come that way.
Old 08-19-2014, 12:08 PM   #6
Arefbee's Avatar
By the master bed would be better. Often use the phone or tablet as a kindle at night then let it charge.
By the entertainment center would be good too since it is fairly central.
The net does not look too classy; maybe in black or brown to go with the decor would blend better.
2011 PrimeTime Tracer 2600rls
2001 GMC Yukon XL 2500, 6.0L 4.10:1 axle ratio
Nights camping 2014 - 17
2013 - 15
Arefbee is offline   Reply With Quote
Old 08-19-2014, 12:26 PM   #7
GM
bclemens's Avatar
We would still like to get something by the beds...but our main buyer is families. Up by the dinette/sofa means everyone can use it. Looking for single USB ports or a combo USB/100V for night stands.
Right now, the wall is tan, the net is tan. I didn't want the net to stand out, just blend in. I have asked for tan mounting tabs...I want it to not stand out.
Old 08-19-2014, 12:33 PM   #8
Arefbee's Avatar
You're correct, the tabs are the problem.
Is the net big enough/strong enough for an iPad?
2013 - 15
Old 08-19-2014, 12:36 PM   #9
GM
bclemens's Avatar
yes. We sized it for an iPad specifically.
Old 08-19-2014, 12:42 PM   #10
Rugged Brown's Avatar
Good thinking to what looks like a great idea. Should have the same setup in the bedroom and living areas, for flexibility.
Terry/Bernadette
Lily the Yorkie
2015 Dodge Ram Sport 1500
2015 Crossroads Zinger ZT28BH
Rugged Brown is offline   Reply With Quote
