Old 09-28-2007, 07:05 AM   #41
RAC
Actually you will put the antifreez into the side of the tank, which is the suction side of the pump so that you pump pumps it to the fixtures.
RAC is offline   Reply With Quote
Old 09-28-2007, 07:17 AM   #42
Okay let me make sure I do understand. One side of the pump goes straight to the fresh water tank. The other side is the one that goes to all the pipes. I will remove the hose that is connected to the side of the fresh water tank, and installed my kit, right?
wengerda is offline   Reply With Quote
Old 09-28-2007, 07:23 AM   #43
RAC
yes, the suction side. I am not sure what your "kit" is. The easiest is to un-attach the hose on the suction side of the pump (goes to your tank) Attach a tube about 18 inches long to where you just removed the tank tube. Put the end of this tube into you anti freeze jug (NON TOXIC Antifreeze), open a spigot to get pump to pum...when you see pink, close spigot. do same for shower, toilet, bathroom faucet...whatever. should use about 2 gallons of anti freeze. Pour a lil down each sink trap.
Old 09-28-2007, 07:34 AM   #44
This is the kit I am planning to purchase:
http://www.campingworld.com/browse/s...=6279&src=SRQB
Old 09-28-2007, 07:37 AM   #45
RAC
I can't look at it at work, they filter "Shopping".
Old 09-28-2007, 07:39 AM   #46
okay is one that Camping World sells. "Pump Converter Winterizer Kit"
Old 09-28-2007, 08:55 AM   #47
I marked with an arrow where to add my winterization kit, Is this the right place?
http://wengerda.myphotoalbum.com/vie...1&id=IMAGE_016
Old 09-28-2007, 09:06 AM   #48
AKA Bluebird
dimurrrw's Avatar
Send a message via Yahoo to dimurrrw
Yep.
dimurrrw is offline   Reply With Quote
Old 09-28-2007, 09:14 AM   #49
Good I think finally i will be ready to save at $115.00 from Camping World or the other RV dealers in my area. I can not understand why the do charge so much to winterize the RV. It only takes 15 minutes when you know what you are doing. In the other hand, they want to charge me $50.00 plus parts to replace oil/filter for my Onan micro-quiet 4000 generator. I will need to read the manual to see how easy/difficult is to do change the oil/filter for the generator.
Old 09-28-2007, 09:36 AM   #50
What about the city water/fresh tank connectors outside the camper, do I really have to remove that little screen and washer and push the white button on it? What about if I do not mess with that? I know that previously, all the 'professional" rv technician never messed with that either.
please read my quote to answer me.
And what socket size I need to remove the bolt for my Suburban water heater?
Thanks again.
sunseeker le
