Old 09-03-2014, 03:28 PM   #11
The fridge drain is usually routed through an opening in the fridge access panel. On my 3010 there is a hot and cold water low point drain. The hot water has a screw cap on it. The cold water does not and there is a valve at the water pump/water filter. If all else fails contact your dealer they should have explained that in the walk through
kswing60 is offline   Reply With Quote
Old 09-03-2014, 03:49 PM   #12
ARLO
Could be the low point drain for the unit.
rlocicero is offline   Reply With Quote
Old 09-03-2014, 04:00 PM   #13
GM
bclemens's Avatar
That looks to be right below where the water pump and filter housing are. Open the storage compartment above that leak. Inside there is a Black ABS panel. Open that door, behind there should be valves for the low point drains. (to the right of the water pump)
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
Old 09-03-2014, 05:49 PM   #14
wplate's Avatar
Thanks all. There is a screw cap on it. Loosened and more water came out. I was able to tighten it a but and the dripping stopped.
2013 Sunseeker 2860DS
2014 Jeep Wrangler Unlimited
wplate is offline   Reply With Quote
Old 09-03-2014, 06:07 PM   #15
Kaadk's Avatar
Ah, ok. Screw cap = low point drain. You take that cap off when you winterize to drain the water from the lines before replacing with RV Antifreeze.
The surest way to lose is to play Marco Polo with a ventriloquist.
Old 09-07-2014, 07:32 AM   #16
trdutch's Avatar
What is this drain?
Too bad yours isn't as obvious as mine and the tech went over it with me but mine are blue and red and as you have found out low point drains to completely drain your water system
Yours look like they got foamed over
I never saw a Hearse towing a Trailer
'71 Dads VW camper pop up Van
'78.....tents
'93 Coleman pop ups (I'm Dad)
'04 Fleetwood Jamboree 26q
'14 Sunseeker 2860DS
trdutch is offline   Reply With Quote
Old 09-07-2014, 07:35 AM   #17
trdutch's Avatar
What is this drain?
Off topic
Did you add the exhaust tip or was it an installed option
My stock pipe Is hideous!
'78.....tents
Old 09-07-2014, 10:31 AM   #18
wplate's Avatar
Originally Posted by trdutch View Post
Off topic
The exhaust tip was added by the muffler shop when my exhaust was moved in order to make room for the HWH leveling system we had installed.
drain
