Old 02-18-2018, 02:35 PM   #1
Hoglou's Avatar
what is this in the wall?
Inside the access port of the shower I found this black 3/16 tube running top to bottom. Almost like a vacuum line, too small for power.. what is it?
Hoglou westGA
BK the DW
KM4HQQ 146.640mhz
Check out the "mods" in the albums
Old 02-18-2018, 02:36 PM   #2
SeaDog's Avatar
Your pics didn't come thru I tried to delete this but is still cam out sorry
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 02-18-2018, 02:45 PM   #3
Sure it is tubing and not coax cable for TV/Satellite?
2012 CC 36CKTS Touring Edition
2015 Ford F-350 CC DRW Lariat
Joe_GA is offline   Reply With Quote
Old 02-18-2018, 02:59 PM   #4
Looks like tv coax cable to me
Kimber45 is offline   Reply With Quote
Old 02-18-2018, 03:00 PM   #5
Hoglou's Avatar
Too small for coax, and to soft. Did not squeeze it much in case it is a vent or vacuum...
Of the choices of 120v, 12v, water, coax it is none of these....
Top rear camera line maybe?
Hoglou westGA
BK the DW
KM4HQQ 146.640mhz
Old 02-18-2018, 03:06 PM   #6
BandJCarm's Avatar
Coax SHOULD have writing on it.......RG59, RG6, something. Other types might also. Are there any numbers, etc., on it anywhere?
FROG AR-0019-242
BandJCarm is offline   Reply With Quote
Old 02-18-2018, 03:30 PM   #7
Get a mirror or stick you phone in the hole and take a pic, both up and down, and see if you can figure out where it goes, then go there and try to follow it until you come to something you recognize.
Does your shower have a removable heat duct vent (or the rectangle it would be in IF you had such a vent) that you can open and look under the shower to see where it might go?
Come back and let us know when you figure it out.
2011 Traverse LT, 3.6L, FWD
Old 02-18-2018, 03:32 PM   #8
nomad297's Avatar
Do you have an ice maker in your freezer?
nomad297 is online now   Reply With Quote
Old 02-18-2018, 03:36 PM   #9
Hoglou's Avatar
solved
I looked under the driver's dash. It is the same cable type as the rear camera....
Now I know. There is a lot of slack in the line but we do have a short coach.
Thanks all..
Hoglou westGA
BK the DW
KM4HQQ 146.640mhz
Old 02-18-2018, 04:12 PM   #10
Thanks all..
A lot of times coax and other wires for accessories come with both ends "finished". Wire's fairly cheap so the people who make the accessories often make up wires for the maximum distance they expect them to run. Installers then just stuff the extra into a convenient void.
I just installed a Victron Battery Monitor and the "data cable" was about 10' longer than I needed. I just stuffed the extra into a void and secured the wires on both sides of my "storage point". Out of sight, out of mind.
Sami. my Shih-Tsu "Co-Pilot" R.I.P
Politically Incorrect since 1943
"Sometimes you're the dog, sometimes you're the tree"
2004 Nissan Titan
TitanMike is offline   Reply With Quote
