Old 09-21-2016, 06:32 AM   #1
What mntc schedule do you follow for the Ford E450?
I am getting ready to change my oil this weekend at 15,000 miles and got to thinking about the maintenance schedule recommended by Ford. I looked through the owners manual for the E450 and I am not sure I will follow their schedule. So let me cover each area below.
First up is probably the most controversial and that is the oil change. I tend to change my vehicles every 5k where the manual says 7,500. I do use Mobil 1 full synthetic.
Next up is one that seems odd and that is changing the air filter every 30k. I do them at 15k and I am not sure I have seen a vehicle recommended to go as far as 30k before.
The transmission for the 5 sp. says every 60k but I usually do 30k if they are in extreme service. If any vehicle I have ever owned operated under extreme service I would say this RV with 12k - 14k lbs and towing a 3,200 lb car would qualify.
Spark plugs say to do them at 97k and coolant at 6 years or 105k which I will not have anywhere near 105k in 6 years.
So do you follow this schedule or do you have your own preferences?
2014 Sunseeker 2860DS
gmacklem is offline   Reply With Quote
Old 09-21-2016, 07:59 AM   #2
grumpy0374's Avatar
Oil change every 5000 miles, synthetic 5w20, Ford 820S oil filter. Also lube front end grease points. Air filter, Ford or Wix at 12000 miles. Just changed air filter before going on current trip. Only had 13000 miles on it and it was already really dirty. So now, every 12000 miles. Havent hit coolant/brake/tranny fluid mileage yet.
Grumpy
Steve & Cheryl + Charlie & Casey, our furry kids.
2012 Forrest River Lexington 283ts
Toad, 2013 Subaru XV Crosstrek
Currently on a 3 month, 12,000 mile trip.
grumpy0374 is offline   Reply With Quote
Old 09-21-2016, 03:56 PM   #3
Grumpy
I haven't checked for any zirks under there. Any recommendation on what kind of grease to use? I have some bearing grease I used on a car dolly, will that work?
Old 09-21-2016, 04:13 PM   #4
grumpy0374's Avatar
There's 4 zerks. 2 upper ball joints, 2 on steering linkage.. Just regular bearing grease will do fine.
I just give em a quick squirt if needed at each oil change.
But, check your rig as some E-450 have plugs on the ball joints and no zerks. Seems there's a bit of difference as to whether or not there installed. Some have em and some don't.
Grumpy
Old 09-21-2016, 04:16 PM   #5
Grumpy
Thanks. I will be changing the oil this weekend so I will check for zirks. I didn't see any mention of them in the owners manual for the 2013 E-450 so maybe it doesn't have them.
Old 09-22-2016, 12:39 PM   #6
gizmo98's Avatar
I have a mechanic instructor that mentioned use full synthetic grease save on potential failures in the future ( pay a little more for full synthetic )
Rob & Elizabeth Sweeney
Having fun in our Forester Gump (2015 3051S forester)
gizmo98 is offline   Reply With Quote
Old 09-22-2016, 06:52 PM   #7
vasnipe's Avatar
Maintenance schedule
I tracked down this link on the Ford web site to supplement the owner's manual I got with my rig. Some useful information.
Maintenance Schedules | fleet.ford.com
Hope this helps some.
Chris in Virginia
2006 Sunseeker 3100SS/LTD
2008 Smart Passion Cabriolet TOAD
1986 Honda Helix (Original owner)
vasnipe is offline   Reply With Quote
Old 09-22-2016, 07:58 PM   #8
ilmor's Avatar
I just follow the schedule per the manual. I feel that doing otherwise is just wasting time and money.
2017 Forest River Sunseeker 2250SLE
ilmor is offline   Reply With Quote
Old 09-23-2016, 08:32 AM   #9
x2
Marcel & Jenne
Kemptville, ON
2014 Rockwood 8282WS
2015 Ford F150 Eco-Boost
BusyRetirees is offline   Reply With Quote
ford
