Old 10-31-2015, 07:38 AM   #1
what size compresor
what size do you use blowing out lines.
retired on a mountain is offline   Reply With Quote
Old 10-31-2015, 07:48 AM   #2
Who Dares, Wins
doc73's Avatar
Any size will usually work, I just keep the psi regulated down to 30 or so psi.
Sent from my SAMSUNG-SM-G870A using Tapatalk
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline   Reply With Quote
Old 10-31-2015, 07:51 AM   #3
LaxRef93's Avatar
Exactly.. keep the pressure at 30psi.
2014 Tracer Ultra Lite 2670BHS
2014 Ram 1500 Crew Cab 5.7L Hemi
Camping Trips 2014 - 3 trips, 7 nights
Camping Trips 2015 - 2 trips, 4 nights
(7 more trips planned)
LaxRef93 is offline   Reply With Quote
Old 10-31-2015, 07:55 AM   #4
Who Dares, Wins
doc73's Avatar
Do not use those tire pumps on the jump packs and such.. Either a normal 110 compressor or maybe (do not have one to say one way or the other) viair style 12v ones. But you need them to be able to move a few cfm and a tank helps to stabilize the flow if you will so the compressor does not need to keep running.
2015 ChevyHD D-Max
Old 10-31-2015, 07:57 AM   #5
fonzie's Avatar
Just make sure you get a "oil less" compressor so you don't contaminate the water lines.....
Fonzie
Nights Camped:2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36) 2017 (32) 2018 (42)
