Old 03-10-2019, 05:10 PM   #1
What TPMS do you use
I am ready to buy tire pressure system for my 3010DS. Looking for recommendations, what it to also work with my toad. I am amazed at the wealth of knowledge on this site so I always check here before making a purchase.
Mike3393 is offline   Reply With Quote
Old 03-10-2019, 05:24 PM   #2
Trailer Park Supervisor
NJKris's Avatar
I bought a TST system based on all the good reviews I read here. Haven't used it yet. Can accommodate all the wheels you can throw at it, including TOAD. comes with a repeater, so the wheels all the way in the back can throw the signal up front.
NJKris is online now   Reply With Quote
Old 03-10-2019, 06:26 PM   #3
dbledan's Avatar
TST 507 with the cap sensors is what I use. It is the most flexible monitor in terms of amount of tires and various pressures. You could also get the flow through sensors but I did not. You will want steel valve stems for the MH if you do get flow through sensors.
Many of the cheap ones would have issues with the toad and a MH because of the tire pressure ranges so check closely for something that can support 35lbs and over 100 as well depending on what your MH requires.
Whatever you get I would get the repeater. Most default to them now. They are more reliable that way. I had issues when I left a wireless thermometer on that would make it intermittent to update the tires and the repeater resolves this. Every tpms uses the same unlicensed frequencies and has the same issue from the research I did.
Best of luck!
dbledan is offline   Reply With Quote
Old 03-10-2019, 06:33 PM   #4
I have the cap sensors as well and I take the security device off. Makes them lighter for times I use them with rubber valve stems and easier to take off. The flow thru sensor have had air leakage issues in the past as well.
2017 Coachmen 233RBS
2018 Ford F150 Lariat 3.5 Eco
"Common sense is not very common"
babock is offline   Reply With Quote
Old 03-10-2019, 06:39 PM   #5
Scoundrel
HangDiver's Avatar
X3^^^^
2014 Micro Lite 19fd
2015 F-150 5.0L V8 XLT Crew Cab, 4x4, Tow Package, 36 gal tank, 3.55 locker, 1891 payload, Integrated Brake Controller
Wooden Spoon Survivor
HangDiver is offline   Reply With Quote
Old 03-10-2019, 08:29 PM   #6
Camper
x4 TST
Thanks,
Brian
TV - 2006 F350 6.0 DRW CC
TT - 2018 Wildwood 31KQBTS
Macrosill is offline   Reply With Quote
Old 03-10-2019, 08:47 PM   #7
Mr. Dan's Avatar
TST 507 - flow-through sensors on metal stems. No issues.
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 =111/'19 = 40; booked = 14
Old 03-11-2019, 08:09 AM   #8
Garrette's Avatar
I use the TT-500 for 4 years now. Works, batteries are replaceable with a lifetime warranty. I am happy with it. Use it for the MH and toad. I wish it had other programming modes. With and without toad would be nice. Without toad, it will alarm lost signal which is true the toad is sort of lost.
My MH is 32' and no repeater is necessary.
2014 Sunseeker 3170 DSF
Dorothy, Garrette and Miss Bella.
Retired and having fun.
Garrette is offline   Reply With Quote
Old 03-11-2019, 09:07 AM   #9
Hi,
I have had TST flowthroughs for many years and recently upgraded to the color monitor.
I still am using my original sensors. I do a battery change every two years, and aversge about 5,000 miles a year on them.
Extremely satisfied in every way, FWIW.
Rich Phillips
Rich Phillips
2009 K-2500 Duramax
2014 Silverback 33RL
richp is offline   Reply With Quote
Old 03-11-2019, 09:22 AM   #10
Wandering's Avatar
Very happy with my TST flow thru. It provides peace of mind to see tire pressure without having to check them.
Forester 2451s
Wandering is offline   Reply With Quote
