Old 07-11-2018, 02:04 PM   #51
I would be interested to see how the rubber boots hold up over time with all of the bouncing on the road.
AbdRahim is offline   Reply With Quote
Old 07-11-2018, 05:55 PM   #52
Hoglou's Avatar
framed out
I did later consider the downward thrust load on those boots so I replace the support bracket. Instead of the top factory hanger, or I would say a stabilizer at best, I changed to a support base to take the complete thrust load from the bottom up (you can see the tip of the bracket at the bottom center). Now the clamps only compress for a seal and are not weight bearing. I cut down a left over Lehigh ladder hanger I had and used a 3"x6" galavinized steel back plate on the rear of the rotocast wall. The funniest thing of all is that I only had grade 5 bolts that size in the shop.... for a plastic wall....
She don't move at all now.
From my album
ID:	179128   Click image for larger version
ID:	179129   Click image for larger version
Hoglou westGA
BK the DW
KM4HQQ 146.640mhz
Check out the "mods" in the albums
Old 07-12-2018, 09:59 PM   #53
Man you are creative.
Old 07-14-2018, 09:25 AM   #54
Hoglou's Avatar
thanks..
Thanks, but those arn't the words BK the DW uses... It more like LITHA (leave it the heel alone). But we stayed in the coach last night and BK the DW did like the idea of starting the coffee from the bed, I also use one of the remote powers to turn on a light in the cab area so I can 10-100 @ 0 dark thirty and not stub my pretty little toes....
Hoglou westGA
BK the DW
KM4HQQ 146.640mhz
Old 07-15-2018, 03:40 PM   #55
125992's Avatar
Originally Posted by nrkmann View Post
This list represents about $4k and hours of work on a 26.5í Springdale without slides. If you donít boondock you can save about $1k.
Real mattress
Shelves in hanging locker by bed (our TT has a large hanging locker so the shelving is a better use of this space)
Bedroom TV shelf gone
Coat hooks on wall at foot of bead
HD gas struts to lift fully made bed
Light & heat pad for bedroom and bath vents
Oxygenics is shower head
Larger medicine cabinet with secure latch
Towel racks in bath (ours is a dual bar)
Toilet paper holder in bath (ours is vertical mount post style up by the sink so it is easily accesable and the TP cannot come off during travel.)
Drying rods in shower (expandable rods fit nicely above shower walls)
Titanium white Velcro mounted skylight cover
Fantastic fan (I think these are over rated and expensive and we will select another option on our next TT)
Wall mounted knife rack (ours is a 1.5Ē stainless box that I cut a styrofoam insert so the knives would ne secure while traveling)
Marine locking latches on all cabinets so the cabinets cannot open while traveling
Wall mounted flat screen 1080p TV (also doubles as computer monitor)
Mac Mini mounted on wall near TV (use Apple wireless keyboard and mouse for use from dinette or couch. Audio wired into TT speakers. Has lots of music and movies loaded on a 1tb HD)
WiFi extender with outside antenna (mounted to TV antenna with coax taped to roof)
Extra USB ports by 12vdc plug
Grab handle inside door
Three coat hooks mounted on the cabinet by the door
Footman loops mounted by the door to strap in walking sticks and umbrellas
Flashlight clips mounted on top of window valences.
High quality water filter from fresh H2O tank (your Camco filter only filters orders etc. It is activated charcoal, not a filter for particulates or pathogens.)
Digital thermostat
LED lights everywhere, in & out
3kw inverter in basement & plug into 120 AC power
25í quick disconnect gas line for BBQ grill
Electric young jack
Outdoor shower enclosure if you boondock to minimize the use of the gray water holding tank.
Four Optima 6vdc batteries if you boondock to drive the 3kw inverter (heavy, so mount in basement to lower their effect on young weight)
Inverter generator for boondocking
Battery shutoff for storage
Vent covers (one has to be for the Fantistic fan tin the bath
Bike rack (ours is mounted very wide for our tandem and leaves the spare tire in its original position)
Insulated reflective cut outs that mount under the pull down shades to keep the TT cooler or warmer depending on the weather.
What tandem bike rack do you use? Would you recommend it?
Bill
2015 Coachmen Leprechaun QB220 (purchased April 2018)
2018 Days Camped - 35
125992 is offline   Reply With Quote
Old 07-16-2018, 03:36 PM   #56
Hoglou's Avatar
nrkmann
I may be an engin'er, but dang that's a list of a craftsman!
I'll jump in on the bike rack, we were using a fixed swagman. But we went to folding citizen bikes last year that ride inside of the jeep. Since we are more of a space shuttle and not a dreamliner I now use the rack as a base for a folding table as my cooking station. It gets used at every campsite, woild be lost without it....
The top black horizonal line is just optics, it's not part of the bike bar, but the opening under the coach.
Hoglou westGA
BK the DW
KM4HQQ 146.640mhz
Old 07-25-2018, 12:00 AM   #57
Sunseeker 2400MBW
I would go through and write down every model number and serial number of every appliance, thingie, item that moves or doesnít move I could even imagine. And the name of the company and the 1-800 number. Cause itís going to break. Not if, when.
Full time 2016 Sunseeker 2400WS towing a 2018 Subaru Forester.
Nancyc7 is offline   Reply With Quote
Old 08-01-2018, 09:48 PM   #58
I would have made sure the gauge on the propane tank worked. Took it back to the dealer (Airport Motorhomes in London, Ont.) twice and they claimed they fixed it. We finally gave up because they are 1.5 hours one way trip, meaning 6 hours of driving each fix attempt.
That's the one thing we were never able to repair on our unit since purchasing new.
jst3 is offline   Reply With Quote
Old 08-03-2018, 10:02 AM   #59
Total Loss's Avatar
Mines up and out of the way now.
"If you are going through hell..keep going"
W. Churchill
Total Loss is offline   Reply With Quote
Old 08-03-2018, 01:58 PM   #60
Hoglou's Avatar
sweet
Next time you have the racks unloaded throw a pic up. Would love to see the entire setup...
Hoglou westGA
BK the DW
KM4HQQ 146.640mhz
