Old 07-22-2014, 01:41 PM   #11
Plain Old Member
Actually the plug itself goes there.
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
BigJohnD is offline   Reply With Quote
Old 07-22-2014, 06:28 PM   #12
It for Ipod to interface with the radio
2014 sunseeker 3170dsf V10
cruiserjohn is online now   Reply With Quote
Old 07-22-2014, 07:20 PM   #13
GM
bclemens's Avatar
Nope. The Magnadyne radio came with a 30 pin iPod cord. The head of that cord had/has velcro on it so instead of just dangling around it can be velcro'd there.
On the newer Jensen radios, we got rid of the 30 pin cord since it does not work with the newer apple connectors. Now you can just plug your normal cord into the USB port. But that is what the velcro is for...the 30 pin connector.
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
Old 07-22-2014, 07:21 PM   #14
GM
bclemens's Avatar
whoops...neglected to see page 2 where the answers were.
Old 07-22-2014, 08:04 PM   #15
Originally Posted by asparky View Post
OOPS, also the little red connector under the above hollow spot, any idea what its for?
That is an Ford OEM radio interface that connects where the black button above the Velcro strip is at. No OEM radio - you loose the feature so they blank it off. The plug probably sneaked it when the engine doghouse was removed.
I have used the Magnadyne USB interface with my Android phone but found the Bluetooth connection method was easier. I could stream Pandora (or any music) from the phone to the Magnadyne via Bluetooth - worked great.
bgilly is offline   Reply With Quote
Old 07-23-2014, 01:47 AM   #16
I did look at the ipod cord and it has the Velcro on it and I now know the red connector is for the ford radio. I'm not sure which radio I have, I assumed the Magnadyne radio.. I know some of my adult kids have plugged there iphones and ipods into the connector... So is there a remote control for the Magnadyne radio? I'm gun shy on remotes with several missing not to mention manuals LOL.. Most of our stuff is android, Im thinking Pandora is the way to go but have never used it LOL.. older school USB thumb drives, got tons of MP3 stuff.
asparky is online now   Reply With Quote
Old 07-23-2014, 05:47 AM   #17
If you have the iPhone connector then you have the Magnadyne. Yes the Magnadyne has a remote it is a small white remote.
You can use a thumb drive or SD memory card loaded with you're music and play it on the Magnadyne however the Magnadyne music directory is cumbersome. Pandora or Songza connected via Bluetooth treat the Magnadyne as headphones so there is no controlling the playlist from the Magnadyne. You only can control the volume.
Old 07-28-2014, 11:17 AM   #18
You can purchase an adapter from Apple to plug into the 30 pin plug...The other end of the adapter is Apple's newest plug.
GMax is offline   Reply With Quote
Old 08-10-2014, 04:38 PM   #19
Terrie's Avatar
What is the medal " button" in the spot for?
Sent by Forest River Forums
Terrie is offline   Reply With Quote
Old 08-10-2014, 05:15 PM   #20
GM
bclemens's Avatar
I think I might have remembered at one time...but it is a Ford sensor that does not get used on the RV chassis.
"Some things we may never know"
