Old 02-17-2015, 06:57 PM   #1
geezer with gadgets
757Dave's Avatar
Wheel Chair Access
We are trying to figure out a way to get a family member into the Sunseeker 3170 while in a wheel chair. We have looked at different ramps online, but they all seem to be too wide for the doorway. Asking this to see if someone may have already solved this issue.
Sent from my Atari 2600
2011 Sunseeker 3170ds "Ladybug"
2017 Jeep Grand Cherokee TOAD
Days camped 2015: 37; 2016: 66; 2017: 86 2018: 57 2019: 5
757Dave is online now   Reply With Quote
Old 02-17-2015, 07:26 PM   #2
Mojojojo's Avatar
Do you know for sure the chair will fit in the door? I have seen one person use a dog ramp for a kids chair. You may have to have one custom built.
My wife keeps saying I don't listen to her -Or something like that?...."My advice has no basis ,more reliable them my own meandering experience" Baz Luhrmann
2011 Sierra 355QBQ 1986 F350
Mojojojo is offline   Reply With Quote
Old 02-17-2015, 07:41 PM   #3
geezer with gadgets
757Dave's Avatar
Thanks for your response. Yeah, we measured the door and it is wide enough. This is for an adult. I'm concerned that a pet ramp will not be sturdy enough. Thanks for the suggestion, though.
Old 02-17-2015, 07:50 PM   #4
Mojojojo's Avatar
We had a dog ramp for a 180 lb rottwieler I believe it was rated at like 200 lbs if I remember right ,one can also modify it with 1 inch square tube steel for added weight. Measure the wheel width ad 1 inch, weigh the chair and occupant I'm sure something is out there. Or have one custom built but it might get spendy.
Old 02-17-2015, 07:55 PM   #5
caper's Avatar
I made a set from 2x8 and attached 1x4 along outside edge. I used the metal end you use to make ramp to load items into back of truck. No problem getting the chair up or down. The plus side is you can make the ramp as long as you want to make a low slope.
This is a low cost and easy way to make ramps. Plus when the ramp is no longer needed you can cut the board to use under the jack of trailer.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 02-17-2015, 09:09 PM   #6
geezer with gadgets
757Dave's Avatar
Mojojojo and Casper, thanks for the suggestions. I will check these out.
Old 02-18-2015, 09:36 PM   #7
I believe a company builds an electric lift for wheelchairs specifically for motorhomes. Suggest google search.
scoto is offline   Reply With Quote
Old 02-19-2015, 12:41 PM   #8
geezer with gadgets
757Dave's Avatar
Thanks. We are checking into that. I was asking here to see if anyone had any experience with any particular method of getting access to their MH with someone in a wheel chair and the pluses and minuses of their experience. Everyone has been very helpful and we have been amazed at the people who attempt to lend a hand. The term "Good Samaritan" come to mind. Thanks again to everyone.
Old 02-19-2015, 01:54 PM   #9
caper's Avatar
If the wheel chair is for occasional use I would not spend the $$$$ for a lift.
Another option is as in picture. Cost for hardware in Canada is $99 plus cost of 3/4 ply wood. Weight capacity is 800lbs. It can be made to any width by 8ft. long. It folds in 1/2 for easy storage.
Terry and Janet
2007 Ford F150
Old 02-19-2015, 02:54 PM   #10
geezer with gadgets
757Dave's Avatar
Thanks Caper. This looks like something we could use. Could you tell me what those parts are called? I printed the picture to take to the hardware store. Thanks again.
wheel
