Old 01-07-2016, 12:38 PM   #1
Delco Bobby's Avatar
Wheel Cover installation? Sunseeker 2250
I removed the front wheel covers from my Sunseeker 2250 to check the tire pressure. It is on the Chevy 4500 Express Van chasis. Removing them was easy with the help of a large screwdriver.
What is the trick if any for putting the wheel covers back on? I had a brutal time and I am exhausted. They look like they are properly attached now but I envision seeing them rolling down the road along side me after I hit a bump.
I need to check the rear tire pressures but it may take me a month to recover from the ordeal of the front covers.
Bobby
2017 Dynamax REV 24RB
2018 Ford F-150
Delco Bobby is offline   Reply With Quote
Old 01-07-2016, 02:26 PM   #2
17Racer's Avatar
They are brutal to reinstall. A heavy rubber mallet is needed. And the spikes just dig into the wheel right down to the metal.
I cleaned my wheels and sprayed the areas that were dug up with semi-gloss white. And I am not going to put the wheel covers back on. Just a pain in the neck to deal with when checking the air on or to change a wheel. I also check tire pressure often just to play safe. And costly if one cover comes off and cannot be found. And just did not care to get the proper valve fittings to make filling easier. If a cover comes off they can damage those fittings also.
All the school buses in my area do not have wheel covers either. I am not sure they do anything other than make it look pretty?
2014 Forester 2301 - Chevy
17Racer is offline   Reply With Quote
Old 01-07-2016, 03:17 PM   #3
Thanks, I was wondering about cleaning and painting. I doubt the wheel covers provide the protection of old fashioned hub caps since the covers have so many holes in them.
2018 Ford F-150
Old 01-07-2016, 06:23 PM   #4
Total Loss's Avatar
I put on another set.
I still had to modify them so they would work correctly.
I may look for a set of used chromes or Alcoas down the road.
I agree- the covers are a PITA.
"If you are going through hell..keep going"
W. Churchill
Total Loss is offline   Reply With Quote
Old 01-07-2016, 08:12 PM   #5
geeman53's Avatar
I sold mine in a yard sale.
2016 sunseeker 2250slec
1988 Jayco p.u.,Coleman Plantation p.u.,1989 Jayco class c, Coachman TT,1995 Little Eddie fthwheel,2007 Heartland Sundance 2500 lS fthwheel
geeman53 is online now   Reply With Quote
Old 01-07-2016, 08:15 PM   #6
Ahh, you just gave me an idea. There is an RV junk yard nearby.
2018 Ford F-150
Old 01-07-2016, 08:25 PM   #7
RETIRED
n-e-d's Avatar
Try a dead blow hammer. Shouldn' the harm the cap no bounce back. Have had mine on and off quite a bit this year trying to get the right tire fill extentions
Mary and Me
2015 2650s "Finally"
2015 Jeep Cherokee
2016 Ford Race Car Red 350HD Cargo Van HR DRW EXT DIY Daytripper "Red Roamer"
n-e-d is online now   Reply With Quote
Old 01-07-2016, 08:39 PM   #8
RedLdr1's Avatar
See Here for info on a hub cap tool. It worked on my wheel covers.
Wayne and Christine
2020 Sunseeker MBS 2400Q On Order
RedLdr1 is offline   Reply With Quote
Old 01-07-2016, 10:47 PM   #9
Are your wheels uncovered now?
2018 Ford F-150
Old 01-08-2016, 07:42 AM   #10
geeman53's Avatar
very nice stainless simulators on ours, which don't have to be removed to check the air pressure.
cover, sunseeker, wheel
