Old 05-16-2013, 07:13 AM   #1
Where is the drain for fresh water tank?
I recently purchased a 2013 sunseeker3100ss I am wanting to empty water out of fresh water holding tank .could someone tell me where the drain is located at .I have crawled under motor home and I do not even see a fresh water tank
spudster is offline   Reply With Quote
Old 05-16-2013, 06:07 PM   #2
MotocrossCamper's Avatar
Mine is a lot older then yours, but is your fresh water tank under the bed? If so does the bed lift for access? If it does look for a valve on a hose coming off the bottom of your tank. Maybe somebody with a newer model can chime in but mine is on the inside under the bed.
MotocrossCamper is offline   Reply With Quote
Old 05-16-2013, 07:35 PM   #3
Plain Old Member
Our tank is under the bed. Has a blue pex drain line that protrudes under the motorhome behind the right rear wheel. Can't remember but I believe our valve is in the bay behind the right rear wheel near the water pump. I honestly cant remember if there is s valve or a cap on that drain line. hadn't looked at it in a while. You should have 3 lines under the mh. Hot and cold low point drains, which just have caps on them, and the fresh water drain. Low points are usually next to each other. If I were home I'd snap a picture for you. You should be able to follow the drain line up. There are a few owners on here with that model. Maybe they'll read this thread and help you out better than I can.
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
BigJohnD is offline   Reply With Quote
Old 05-16-2013, 08:01 PM   #4
Garrette's Avatar
On my 3270ds it is next to the water filter
2014 Sunseeker 3170 DSF
Dorothy, Garrette and Miss Bella.
Retired and having fun.
Garrette is offline   Reply With Quote
Old 05-16-2013, 08:01 PM   #5
We have a 2011 3100ss and the valve is located right next to the water pump behind the wall. In order to get to it, you have to remove a section of wall just to the left of the water filter. Valve is located in blue line coming from water tank located under the bed. Good Luck !
parker21 is offline   Reply With Quote
Old 05-16-2013, 08:21 PM   #6
X 2
We have a '13 3100 too. Passenger side, storage compartment two forward from the back, open the little black door inside, valve is inside (along with the water pump).
All previous rigs below are sold - waiting until the kids graduate to the buy the next one!
'13 Forest River Sunseeker 3100 Class C
'04 Fleetwood Sedona Pop Up / Reese Mini 350 / Prodigy / BAL
'94 Coleman Cedar Pop Up
paulmlac is offline   Reply With Quote
