Old 04-01-2013, 05:45 PM   #1
Where is the slide control module
I have a Sunseeker 2250LE and still looking for info as to the location of the electronic control module which annunciates fault codes for the slide. Does this unit have this module and, if so, where is it hidden?
Lou
biglou847 is offline   Reply With Quote
Old 04-01-2013, 06:48 PM   #2
Dave_Monica's Avatar
What you're describing is if you have a Schwintek slide. They have track like the photo...top and bottom on each side of the slide.
If you don't get a response on this post from 'bclemens', send him a PM as he's the factory rep for Class C MHs.
Dave
Old 04-02-2013, 10:36 AM   #3
Dave,
Thanks for the info. Yes, that is the slide I have. But, the 2250 may or may not have the full blown control module. I know bclemens reads some of these posts and will wait a few days to see if he (or someone else) can shed some light on this. If I don't hear I will pm him. He sure does a lot to help lots of folks on this forum, hope to get a chance to meet him and say "thanks" at the FROG rally.
Lou
Old 04-02-2013, 07:59 PM   #4
I don't know about your 2250, but on my 3051 the module is behind a panel next to the floor, directly under the range top. Of course, the only reason I know is that bclemens told me.
Steve
cundie11 is offline   Reply With Quote
Old 04-02-2013, 08:10 PM   #5
Crusader's Avatar
I Have a Crusader with Schwintek slides. My control module is mounted to the floor under the stove drawer ( removed drawer ). The motor wire had came off my controller causing the slide not to work. Re-installed the wire and all was well….
TV= 2012 F-150 FX4 Supercab
FW= 2011 270ret Crusader
Hitch= Reese Pro Series 16K Hitch
Crusader is offline   Reply With Quote
Old 04-02-2013, 08:17 PM   #6
Crusader's Avatar
Keep in mind. … trailers bounce .. Things loosen.. Just a fact
Old 04-03-2013, 04:34 PM   #7
GM
bclemens's Avatar
Lou
Pull the drawer from the night stand, its in there.
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
Old 04-04-2013, 11:20 AM   #8
Found it, but...
Found the module, can access by removal of nightstand drawer, below closet drawer or panel. But, the location does not allow me to read the label. I would be able to see flashing lights if there was a problem but no way to know what they mean. What are the various fault codes?
Lou
Old 04-04-2013, 04:47 PM   #9
GM
bclemens's Avatar
Here ya go.
Old 04-04-2013, 05:33 PM   #10
Garrette's Avatar
Originally Posted by bclemens View Post
Here ya go.
While you are on the line, where is the module on my brand new 2013 3170DS?
Garrette is offline   Reply With Quote
