Old 01-29-2016, 05:10 PM   #1
Where to check/add hydraulic fluid for BigFoot
I've got a 2015 Sunseeker DS3010 with the Quadra Bigfoot leveling system. For the life of me, I can't figure out how to check the hydraulic fluid levels. Can anyone help? Much appreciated....
jeffreymhardy is offline   Reply With Quote
Old 01-30-2016, 01:50 AM   #2
Sagecoachdriver's Avatar
Which model do you have? If you have the Platinum like mine, the reservoir is located in the pump command module on the middle of the frame. I believe there are a couple of screws holding the cover on. Remove the cover and the reservoir is visible. You may need a turkey baster to add fluid.
Not sure about the Fully Automatic model, but the picture on their website shows a reservoir at each levelers atop near the mounting bracket.
Someone may want to chime in with more info.
2004 Winnebago Minnie 22e(went to a nice family Oct 3, 2015)
2016 Forester 2701DS (Aug 31, 2015)
2017 Camping 12 trips 38 nights
2018 Camping 10 trips 38 nights
2019 Camping 6 trips 19 nights
Sagecoachdriver is offline   Reply With Quote
Old 01-30-2016, 08:06 AM   #3
Garrette's Avatar
If automatic, remove cover. The small plastic reservoir is opaque and you can see the fluid level. The fill is on top and difficult to add. Mine are 3 years old and even with a little weeping, never had to add. But to add, you will need a large bore needle, think horse from farm supply, and a length of small hose, think washer hose, . There is no drain, so no way to easily change. I am thinking that the oil does not need changing.
Anyone else want to chum in?
2014 Sunseeker 3170 DSF
Dorothy, Garrette and Miss Bella.
Retired and having fun.
Garrette is offline   Reply With Quote
Old 01-30-2016, 01:30 PM   #4
I use a small pump oil can , one with a flexible spout , that way you can pump it in with one hand. Use Dextron III or IV and no it doesn't need to be changed unless it becomes contaminated.
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
wana65stang is offline   Reply With Quote
Old 01-30-2016, 04:41 PM   #5
Garrette's Avatar
Ahh, good idea. Saw one at the parts store the other day and wondered how I could use it. Back to the parts store. Better that the syringe and small hose.
Old 01-30-2016, 04:45 PM   #6
That's a great idea! HF has cheap ones 4ou and 20ou for $5 or less.
hydraulic
