Old 04-24-2012, 07:47 PM   #1
where's the manual slide crank '02 Sunseeker?
Recently bought 2002 SunseekerLE 3100. Where is the manual crank to operate the slide? DH has looked around for it but hasn't found it.Thanks
chris123 is offline   Reply With Quote
Old 04-24-2012, 07:52 PM   #2
The manual crank is usually on the opposite side from the the the way the slide moves. It will be 3/4 inch nut, on a shaft usually. With the slide out, look at the 2 support rails. The manual crank access is generally in line with one of the rails, just inside of one of them.. Most often, the front one, but not always. May be just under the edge of the siding, or may find an access hole in the siding, with a rubber plug covering the hole. Don't have a Sunseeker, and can't recall working on one lately. The suggestions I gave are generic, for any camper with an electric slide.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 04-24-2012, 08:02 PM   #3
vasnipe's Avatar
Slide manual crank point
chris123, on my 2006 Sunseeker 3100LTD the manual slide crank point is in the storage compartment directly under the slide. Open the compartment and look up inside for the "bolt head". I have not tried to use it yet, but there is not a lot of room to swing a ratchet without a short extension. Hope this helps.
Chris in Virginia
2006 Sunseeker 3100SS/LTD
2008 Smart Passion Cabriolet TOAD
1986 Honda Helix (Original owner)
vasnipe is online now   Reply With Quote
Old 04-25-2012, 09:37 AM   #4
GM
bclemens's Avatar
Sunseeker is a motorhome...trailers have them in the siding, but motorhomes are typically below.
As stated above, there should be a shaft with a hex nut on it. Will be poking straight down below the slide out (maybe the roof of a compartment).
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
Old 04-25-2012, 09:47 AM   #5
OOPS, missed the motorhome part
LadyWindrider
