Old 02-06-2014, 09:13 AM   #11
that is what I will want is stability, I never lifted my motor home's wheels off
the ground.
Yes to the front, not sure how to install them, looking for someone who has
done this already. I don't need to be the leader of the pack.
Phelpo
phelpo is offline   Reply With Quote
Old 02-06-2014, 09:34 AM   #12
TeresaInCAL
TeresaInCAL's Avatar
We added the scissor jacks. 2 in front, 2 in back.
Teresa
2013 f150 Ecoboost 4x4
2009 Gray Wolf, 22BH
TeresaInCAL is offline   Reply With Quote
Old 02-06-2014, 11:10 AM   #13
I'm not sure the model of the jacks as the MH is in storage. It looks like the picture posted by Oldcoot. I think they are simply bolted to the frame. As I mentioned the best advantage is having the cordless drill with a long extension to do all the hard work. I found jacking by hand crank took a few minutes and lots of sweat when it was +30 c, however with the drill this was a pleasure.
Sun.ranger is offline   Reply With Quote
Old 02-13-2014, 07:41 PM   #14
My 2860DS came with rear scissor jacks, it helps stabilize the unit due to the long overhang behind the rear tires. I use them to some degree to level the unit, but that's only an aside. I had a 2300 previous, scissor jacks not really needed.
KQ2N is offline   Reply With Quote
Old 02-14-2014, 04:11 AM   #15
Sportracker's Avatar
KQ2N what year is your 2860? Mine is a 2010 it has a front stabilizer which I was unaware of until I learned about it from other threads here. Its ahead of the wheels and accessed from drivers side
Sent from my DROID BIONIC using Forest River Forums mobile app
Sportracker is offline   Reply With Quote
Old 02-14-2014, 06:38 AM   #16
Sportracker, my 2860 is a 2013 model. It's too nasty outside now to go check, but I've been under the unit to change the engine oil and look around, I don't remember seeing any front stabilizers, but sometimes I'm not that observant. I'll check it out as I have to do an oil change before our March trek south.
Old 02-14-2014, 07:51 AM   #17
thanks guys for your input, I have been looking at the 5000 lb Husky scissor
jacks from the net, they have a flat lifting pad. I was on the net
where a guy screwed 2 2x6 on the bottom of the jack for a better
landing pad. Like I have said, I don't want to lead the pack.
Phelpo
Old 02-14-2014, 11:35 AM   #18
TeresaInCAL
Per request, here's the jacks we had installed (over my capabilities).
Teresa
Old 02-14-2014, 11:39 AM   #19
avolnek's Avatar
OC you amaze me! I love how you mounted them jacks! I was trying to figure out how to mount mine and I think you have settled it for me!
Hopefully you dont start charging for copying you!
TV- 2015 Ram 2500 CCLB 6.7 Cummins 3.42 gears
Camper - 2015 Saber 322BHTS
avolnek is offline   Reply With Quote
Old 02-14-2014, 11:46 AM   #20
TeresaInCAL
Teresa
jacks, class c
