04-13-2015, 06:47 PM
Wifi repeater installation on 3050s- cabling through roof
Want to install a wifi repeater in my 3050, but want a nice clean install. Only two options I can think of for cable run to the antenna...
1) remove existing coax entry plate from the roof, order a plate to accommodate a second run of cable, and then run the cable through the same entry point. Only issue is the existing coax runs through the roof to the opposite side of the RV. The plate appears to be above the cabinets, but I am not sure if I can drill through the ceiling from the existing plate to reach the interior of the cabinet for mounting of the router.
2) run the wiring through the fridge vent and behind the refer. Only issue is how to get the cabling from the back of the refer to a suitable router mounting location.
Anyone tackled this or a similar issue on their 3050 (or 3051) and have any insight on how to get cabling to a good router location? I don't want to put any additional holes in the roof or sidewalls...
Thanks in advance!
04-14-2015, 12:09 PM
Run it down through the fridge vent, No holes have to be drilled, this is where we have all our cables for our solar panels come in to,
04-14-2015, 02:54 PM
Thanks in advance!
I ran my wifi cable thru the hole used for the tv antenna and resealed with dicor.
2011 2902ss Rockwood Ultralight
2008 Grand Cherokee 3.0L Diesel (255 hp @ 2900 rpm / 430 lb-ft @ 1,400-2,800 rpm)
3P ProPride Hitch
RV Mods
Wandering RV Life
04-14-2015, 06:33 PM
WestCoast, with coming through the existing antenna roof hole, did you just bring the second cable run straight down into the cabinet over the couch? Looks like where I would like to end up, and also the cleanest location. However, I just want to make sure that I can drill straight down from that location and end up in the right spot before I pull the existing plate.
I looked at coming through the fridge vent, but once the cabling is behind the fridge, there's nowhere really to go with it that would make for a clean looking install on the router... And I don't want to mess with pulling the fridge.
04-14-2015, 08:03 PM
Below are the pictures from my install last year in my Forester 3051S.
Hope this helps,
Frank
Frank
2016 Days Camping so Far: 24
2013 3051S Forester
2013 Elantra GT (Toad)
WashU EMBA "39
04-14-2015, 09:40 PM
Hope this helps,
Frank
Can that run on 12 volts or does it need 110v.
04-15-2015, 06:34 AM
The wire going through the awning bracket is the RG58 coax cable that goes to the antenna. The repeater gets the 110V through a small AC transformer that I plug into a 110 outlet that I feed from the over cab sleeping area.
Frank
Frank
2013 3051S Forester
WashU EMBA "39
04-17-2015, 11:42 AM
Thanks in advance!
MattAndLisa,
If you can go through the fridge vent this is the way to go. I installed a Willson cell phone booster in our 5th wheel. The installation instructions was to keep the coax cable from the antenna to the booster as short as possible not loosing strength.
I therefor opted to go through the back wall (very scary drilling through the wall), I know you don't want to go through the wall but not as bad as one would think.
I did the installation back in 2011 and have been across Canada and back and then some and it all still looks good. Here is a link to our blog with the installation.
Good luck,
Anders Campbell River,
BC. Canada
Pony: 2017 Dodge 3500 Longhorn 4x4, Quad Cab Chuckwagon: 2020 GD Solitude 310 GK
My RV Cookbook now on Amazon! USA or Canada
Travel Blog
Cooking Blog
